Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos wont turn on
Green flashing light on front of tv but tv won't turn on
  • 7 more comments
  • wendy7eddie Feb 01, 2009
    We just receieved our new Sharp Aquos LC-37D44U and it comes on for only a moment before fading out. The green light continues flashing after the screen has lost power.
  • saymrs Feb 02, 2009
    Our 32 Sharp Aquos Model #LC-G5C32U turns off by its self and won't come back on for hours or days. We have tried covering it when its cold and not being used and nothing seems to work. There is no rhyme or reasons as to why it turns off.
  • EdinaSomlai Feb 24, 2009
    Brand new Sharp Aquos LC-65D64U and the problem is the same. Flashing green light nothing else.
  • Anonymous Apr 04, 2009
    tv will not turn on. after pressing the power button again the OPC and power lights flash.
  • Anonymous Apr 05, 2009
    The green power light flashes at 1 flash/second. The set will not turn on.
  • Anonymous Mar 12, 2014
    it does not turning on but still the outlet was fine
  • Anonymous Mar 21, 2014
    Sharp aquos
  • Anonymous Mar 22, 2014
    We connected the TV to the wall and it won't turn on
    tv wont respond to anything
We were watching our TV and suddenly the picture went out. We still have sound. This is true with any device hooked to the TV as well....sound but no picture.
Posted on Jan 21, 2009
  • 135 Answers
This is either a power problem or the screen needs re-gasing
Posted on Jan 18, 2009
A very simple solution when your Sharp LC-40LE540E (and probably similar ones) does not turn on after a power interruption. Mine just showed a blue power on LED on its front panel for a minute, and then it turned off. The screen remained black. Disconnection of power mains for 10 minutes or more did not help.
The solution:
1. Download latest TV's firmware from sharp.eu site for your TV.
2. Unzip the file and put the xxxxxx.zimage file into root directory of a USB stick.
3. Disconnect TV's power mains from power outlet.
4. Insert the USB stick into USB port of your TV.
5. Connect TV mains to the outlet.
6. Wait until power LED on TV's panel starts and stops blinking red-blue (about 2-3 minutes).
7. When SHARP logo appears on the screen followed by a window asking you to YES-NO update the firmware, select your option with its remote. You may upgrade firmware, if before it was not the latest, or just select NO - if you don't want to, and after that your TV switches on in its regular way.
That's it!
Enjoy!
Posted on Oct 24, 2015
    New Friend:
Power light blinks 2 times and the opc light blinks 5 times
Posted on Aug 10, 2015
    New Friend:
I have aquos tv sharp mol lc-32d43u tv is plugged in but won't turn on
Posted on Apr 19, 2013
  • roberto galdamez Apr 19, 2013
    i have aquos tv sharp mol lc-32d43u tv is plugged in but won't turn on
4 Suggested Answers
Zenodilodon
  • 145 Answers
SOURCE: 52 sharp aquos tv wont turn on. Hear click of tv
This tends to be the result of an electrolytic capacitor somewhere, either on the main board or the power supply board bursting due to overheating. In this case you can pull off the back paneling and review the boards over to make sure all the capacitors are in excellent condition. After identifying a bad capacitor you can buy one from an electronics store in the area or a reputable online source. To replace it this will require soldering. Look for a capacitor with the same uF, the voltage can be the same or higher. Make sure all the power is out of the system before servicing, also make sure to note capacitor polarity observing the negative indicator line on the side. If your not sure this can be done at home I would recommend taking it in to a servicing shop. If you do not know what a capacitor looks like do a google image seatch for both examples of a good and bad copacitor. I honestly hope it's something much simpler, I hope this helped and good luck.
Posted on Mar 03, 2010
carmine8507
  • 7 Answers
SOURCE: sharp aquos red flashing light tv won't get picture
if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Posted on Nov 09, 2008
bugoy31
  • 1238 Answers
SOURCE: 60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Posted on Dec 19, 2011
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Televison & Video
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Tv won;t turn on little green light flashes on power button
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
3,324 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
