Kenmore Model # 110.26842691- will not drain after cycle. machine shuts down upon reaching that point.
    Problem Solver:
  • 13 Answers
Replace the lid switch. part number 3949238 about $31.00
Posted on Jan 17, 2009
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Washer does not completely drain to allow for spin
The most common cause for standing water in a washer is a clogged drain pump. Another possibility is a kink or clogged drain tube. Below is a youtube video with instructions on removing a drain pump on most front load washers including your Frigidaire model. Best of luck and thank you for using Fixya!
Dec 26, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
I have a kenmore washer model 110.22994. It fills with water but does not agitate. How do I start to identify the problem? The problem started after a friend loaded the machine with heavy jeans.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool / Kenmore service manual for top load, direct drive washers with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing to check is to try the washer on a different cycle.
Then make sure that it will drain and spin.
If it will work on a different cycle, the problem points to the timer.
If it still won't agitate and it WON'T drain or spin the problem points to the Lid Switch
If it will neither agitate, or spin but will drain, the problem points to the Motor Coupler.
Jan 09, 2010 | Kenmore 22982 Top Load Washer
I have a top-load washer that began leaking at the front of the unit. The water is dripping from the front-center of the machine. It begins leaking immediately upon filling and will continue to leak for...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the area for the motor and pump.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 23, 2009 | Kenmore Washing Machines
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
