Question about Microwave Ovens
Everything works but won't heat
I have only had the microwave 2 weeks it is a Panasonic Inverter microwave, I had noticed after a week that food was not heating as good it would take longer and now it won't heat anything but everything else works on it.
    Genius:
  • 1,199 Answers
What you got was an oven with a bad MAGNATRON (this is whats the food!) I would return for replacment oven!...This is a common problem with these ovens!
I hope I was of big help to you!
Please rate this FREE solution!
Thank You!
Posted on Jan 17, 2009
Panasonic Dimension 4 Microwave- Model NN D801. Whilst microwaving for 2 mins on high - heard a zapping noise. Didnt heat food. Front operating panel works. turntable still works. Any suggestions?
A "zapping noise" usually indicates a problem in the high voltage circuit. If it's an inverter oven, it should have provided you with a fault code. If a non-inverter, the most likely causes are a shorted high voltage rectifier or bad magnetron. But there are many other possible causes.
Oct 02, 2016 | Panasonic Microwave Ovens
Error H97 on Panasonic Inverter NN-SF 550W microwave... working but not heating food
Likely inverter problem. For the testing procedure,go here:
http://educypedia.karadimov.info/library/Inverter.pdf
Sep 05, 2016 | Panasonic Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
I have a panasonic inverter microwave model 1250w and does not heat up, everything else works fine
its likley to be the magntron burnt out,,(thats the bit that heats the food up) its a pricy part to buy and have fitted,,it may be a lot cheeper to buy a new unit
Jun 20, 2010 | Panasonic NN-S254WF Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
My Panasonic Microwave Genius 1300W will not heat up the food and the rotate dish spins and the sensor reheat will not heat up the food. Nor cook Pop Corn when pressing the buttons to 2:00 cook time. I...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 14, 2009 | Panasonic NN-S960WA Microwave Oven
Microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Comination Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
I would think it's not a door switch problem since the oven and grill work.
I'd say this is a problem with the inverter or a bad magnetron.
More importantly, due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Nov 27, 2007 | Microwave Ovens
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
