Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Philips/whirlpool turbo silent 256 , no water through the cycle
Whirlpool Turbo Silent 256 dishwasher, I can hear the water pumping but not spring the water to wash the dishes.
Thanks
  • 32 Answers
Hi, if the motor is working then the spring arms are blocked. Pull them out and rinse them on the sink, then put them back on. Simple
Posted on Feb 12, 2009
Whirlpool Quiet Partner II Dishwasher is banging during fill cycles. I have to run the sink faucet to stabilize the pressure. Do I replace the inlet valve or the hose, or is it some other part? It used...
Sounds like you may need to call someone who can repair it because built in dishwashers are harder to fix if its a valve.. may need a new dishwasher if you say its getting worse..
Mar 19, 2015 | Whirlpool Dishwashers
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
Whirlpool Gold Silent Partner IV Dishwasher - model Anyway, my PROBLEM is that the control panel isn't working!!! At all!!! Only the cancel button works... Do you have any solutions?
I think the problem here is there is water in the control panel. this can happen and short the other buttons out the cancel has its own circuit. I would recommend changing the control panel.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water pump problem
Is the exit pipe blocked? Have you made sure that the filter is not blocked? Can you hear the pump working or does it sound strange or silent?
If these are OK then you may have a genuine water pump problem then call a service engineer. If you are competent to do so and have the tools make sure the power is turned off and the inlet water feed is closed off, then remove the water pump yourself and check that it works and is clear of any obstructions. Also check that the feed pipe to the pump from the drum is not blocked.
Sep 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher- whirlpool (silent partner I )
Sounds like you are not getting water I'd check the water valve first.
Jan 28, 2009 | Whirlpool Dishwashers
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The cups and silverware come out with food on them
I recommend rinsing the food off before placing the items in the dishwasher. Also, run the hot water in the sink until it is hot before you turn on the dishwasher. good luck
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
1,237 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
