Question about Kenmore Elite 45986 Front Load Washer
Error codes f and h
Washer stops in the wash cycle with the error code f and h
I have the HE 3t and an error code of f flashes at the 9 minute mark. Can any one help with this problem? When I contacted customer service that told me to unplug the machine and plug it back in. This did not solve the problem. Any suggestions?? Thanks, Paula
Posted on Jan 18, 2009
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
    I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
    Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
    The machine stops after the wash cycle and won't finish.
    The code is UE
    load too small.
    • Load is out of balance.
    • The washer has an imbalance
    detection and correction
    system. If individual heavy
    articles are loaded (bath
    mat, bath robe, etc.) and the
    imbalance is too great, the
    washer will make several
    attempts to restart the spin
    cycle. If an imbalance is still
    detected, the washer will stop
    and the error code will be
    displayed.
    • Add 1 or 2 similar items to help balance the load.
    • Rearrange items to help balance the load.
    please rate this help to keep the service online
    Aug 20, 2009 | LG Washing Machines
    Error code F05 after the start of wash cycle
    F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
    Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
    Error code f22 whirlpool duet wash cycle
    f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
    If you're getting an F22 error, you will want to check anything to do with the door latch switch.
    Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washer stops washing and gives a p5 trouble code
    PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
    F1 error code on Kenmore Oasis He
    Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
    Hope this helped.Let me know by rating me
    For more help go to live chat.
    lenwest
    Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Bosch Nexxt 500 Series Washer Will Not Add Water
    during a normal wash cycle the washer stopped and gave an e;4 error code
    Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
    Kenmore Elite 45986 Front Load Washer Logo
    104 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
