Question about Bose Wave Music System CD Shelf System
Can't get the Bose to work on AM and FM isn't much better
Recently moved to a high rise and I'm having a problem with my Bose....static on both AM and FM. Any suggestions?
You Can Buy A External Antenna For It At Bose.com
Posted on Sep 08, 2007
SOURCE:
I have been getting static on my Bose radio. When I turn the cord that is in the radio to the plug on the floor, it stops being staticy. Should I get a new cord?
The reason that it stops getting static when you move the cord is because you are acting as an antenna. This has nothing to do with the cord. You should probably place the radio closer to a window so it can get better reception.
Jul 28, 2011 | Bose Wave Radio
FM radio works fine. AM radio worked fine when car was new but now it's like you're in a tunnel. Lots of static &/or weak signals. I have to turn up the volume very high to hear anyting on...
If you have window tint that contains metal sputter in it. That can cause interference on your fm/am signal strength. If that's the case change your tint to a carbon fiber tint that does not cause interfernce with your radio
May 29, 2011 | 2005 Volvo S60
I have a lot of static when i'm listening to AM radio on my bose radio
FM reception is good; however there is a lot of static on AM 1000. No problems on other AM stations. Any suggestions or than stop listening to "1000"?
Nov 24, 2009 | Bose Wave Radio
We have 3indoor/outdoor speakers for deck-they are static
I would suggest moving them close to the base unit (if you havent already) to see if that improves the sound quality. If so, then you know you have some kind of interference in the area. Also, what output are you using from the BOSE? If you are using a headphone output or other variable output, you may be overloading the input circuit of the wireless base unit. Try turning down the volume on the BOSE or connecting to a different output.
Aug 19, 2009 | Cables Unlimited Audio Unlimited 900MHz...
Bose Wave Radio...DOA
Unfortunately, Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of their units. If you check the service/repair page on their web site, www.bose.com, you'll find that they will repair most Wave units for $100 or give you $200 credit towards a new model. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price than the Bose.
Bill B.
Mar 20, 2009 | Tivoli Kloss Model One AM/FM Radio
AM static
the easiest way would be to move the radio farther away from the furnace.
Sep 13, 2008 | Bose Wave Music System CD Shelf System
Heavy static noise
Sounds like interference getting in caused by your connecting cables. Suggest upgrading to higher quality ones.
Aug 31, 2008 | Sherwood RX-4103 Receiver
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
Bose Wave Music System CD Shelf System Logo
369 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
