Question about Magellan Maestro 4040 GPS Receiver
I have the Magellan Maestro 4040. The yellow power connecter has come lose/off and is inside unit. I can't seem to figure out how to open unit
    Scholar:
  • 86 Answers
You have to use small screw drivers to open unit and re-align the yellow connector. Maku sure that when all screws are undone. Pry it open carefully not to misplace or misalign any other parts. If the connectore is really broken from the connector board, we need service technician to either solder it for you or replace some parts on the connectore board itself.
Posted on Jan 17, 2009
Port for car charger broken
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Jul 05, 2010 | Magellan Maestro 4040 GPS Receiver
Installed a new battery in my magellan maestro 4040. battery has been charging for over 12 hours. only 2 bars like original battery.
with the 4040 plugged in to the charger, wiggle the cord to different positions and see if it loses contact (stops charging)
this model has a very common problem with the power port failing..iif it loses contact by testing it in the manner i suggested, it will require either a new one install or at the very least, resoldered,
let me know what you find and ill help you further.
bill
Apr 24, 2010 | Magellan Maestro 4040 GPS Receiver
Can I fix loose charger inside the unit of Magellan Maestro 4040?
  1. The only way it can be fixed is to replace thew whole motherboard. about $90.00
please rate our help to keep free sewrvice online
Aug 30, 2009 | Magellan Maestro 4040 GPS Receiver
Loose part at the power input point.
it comes apart take out the 4 screws in the back. you'll need something to pry the back off .start on the side with something thin to unsnap the 2 halfs then use your fingers. after openning you'll need to resolder the powerport back on with a soldering iron and new solder. 4 spots hold the powerport on. it will be stronger than before. mine worked fine after.
May 03, 2009 | Magellan Maestro 4040 GPS Receiver
Problems with Magellan Maestro? 4040 GPS power connection
Wow if you opened the unit Magellan can tell. If your unit was under warranty You might have talked them into a repair (if your very very very persistent with you can get thin done , eventually ) but now you talk to them to see what they can do but it may be cheaper to go get another unit
Jan 12, 2009 | Magellan Maestro 4040 GPS Receiver
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Broken-off power connector
most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.netto open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Nov 05, 2008 | Magellan Maestro 4040 GPS Receiver
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
hi ,
I understand from your mail that the power pin in the unit has been broken.
contact the Technical Support at 1-800-707-9971 so that they will give you a RA number and the address for the repair center.
Mar 07, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
97 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
