Question about HP Photosmart C6180 All-In-One InkJet Printer
Error: 0xc18a0001 - HP Photosmart C6180 All-In-One InkJet Printer
  • matarak Jan 23, 2009
    error: 0xc18a0107
In addition to having the ink system failure error 0xc18a0001, my printer screen also read improper shutdown. After trying most of the above solutions with no success, I did a search for the improper shutdown problem. This is where I found my solution!
The solution is under "Printer will not start" the solution post is by speters9971. "...you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord."
This is what solved my problem after hours of searching & repetitive similar solutions!!! The above solutions did not help; some of them seemed to be incomplete or irrelevant for my model. I have a HP Photosmart 3210 All-in-One.
Thank you speters9971!!!!!!!
Posted on Aug 15, 2009
    President:
  • 1,564 Answers
My all in one was eaten alive by lightning. However during a conversation to ressurect my unit, The service rep from HP told me to power down and then when powering up the unit press the "9" and "select" buttons or the "9" and "options buttons smultaneously and this will clear the memory entirely. Sorry about the 2 choices but it was a long time ago and thousands of questions ago...lol. Thank you, Dana
Posted on Sep 06, 2009
I have the same problem
printer hp 3210 oll in one
I was a crossroads to either ditch the printer or try and fix it. I am glad I tried to fix it. The problem that I experienced was similar. The problem is that the gear that drives the pump may have fallen off (as in my case.)
If you are willing to take a chance take the printer apart. Dissconnect the power.
Remove the screws from the scanner area.(6 + 2)
Remove the pivoting top and take care of the ribbon cables and wire connector.
Remove the side and back plastic covers
Remove the power supply
Take off the two screws that hold the ink pump (white)
pull out the pump and reinstall the gear.
May need glue but I did not use it. Reattach the belt.
Put the machine back together
Do a soft reset
You will be back on line
If this happens again I will glue the gear in place.
Time to fix having never done anything like this before was one hour. Next time it should take less than 30 minutes now I know what the pattern is.
Posted on Mar 19, 2009
This solved the same problem as on my C6180 printer too!! Thanks so much for posting this!!!
Posted on Sep 05, 2009
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
MY hp c6280 says error 0xc18a0106. What does that
ME APARECE Error 0xc18a0001 que devo hacer para que se arregle mi impesora, saludos gracias
Jul 22, 2010 | HP C6280 All-in-One Printer
I get the following error message from C5180 printer: 0xc18a0001. What should I do?
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
5. Wait 60 seconds.
Or try 2
Or try 3
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,690 people viewed this question
Seeker5211
Seeker5211
