Question about Philips 52 In. LCD HDTV
HDMI Connection Does a hdmi cable provide better picture and sound than a regular cable connection?
  • 8,596 Answers
I will issue a piece of friendly advice - while HDMI is leagues better than a regular cable connections, the Philips LCD TV's have a screwy encryption system that will give you new problems - sporadic picture loss. If you want better picture and fewer headaches, use Component (Red, Green and Blue) cables. you will get 1080i, which is till HD - and fewer problems.
-Tha Mp3 Doctor (with my two cents)
Posted on Jan 18, 2009
  • 36 Answers
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Posted on Jan 17, 2009
Where is the Audio out on model NSA-40d40sna14
It is on the HDMI cable, or there is one audio output. Did you read the manual?
3 HDMI inputs for the best home theater connection:High-speed HDMI delivers a full 1080p picture and digital surround sound in one convenient cable. HDMI cable not included. Additional connections:Provides flexibility with component and PC inputs, a USB port and a DVI interface. 1 audio output.
Manual under Support and Downloads
Insignia 40 Class 40 Diag LED 1080p 60Hz HDTV Multi
Dec 14, 2016 | Computers & Internet
Do i need a s cord for sound when hooking up dvd player to tv
  • The connection you choose depends on the kind of connections available on your TV and on your DVD player. Some manufacturers provide only one kind of connection, others two kinds, and still others all three.
  • Regular AV connections provide good video quality.
  • S-Video provides better video quality.
  • Component Video provides the best quality video next to HDMI.
  • HDMI connections are the highest quality connections If need be adapters are available, to switch from S video cable to what you want. Check the attached links,instruction and guides, Good luck.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How Do Connect My DVD Player To My TV
How to Hook Up DVD Player
Video Adapters
Mar 26, 2016 | Audio Players & Recorders
HDMI connection shows no video, but picture shows when COAX cable is connected.
That HDMI connection hub might have shorted out and already dead.Tries tv unplug,replug it back in like about an hour later.For the tv to do a resetting itself back to the factory setting.Try using that HDMI connection hub again might work or not.Try other HDMI hubs for new connections for better chances for the tv to work with HDMI hubs connections again.
Apr 07, 2011 | Televison & Video
I hooked up my HDTV with a HDMI cable but when I used the Audio L/R cables, I can't get any sound. I can get sound if I hook up the TV with regular cables but then I don't get the HDTV picture. Any...
You may have to go into the TV setup menu and change a setting for Sound (or Audio) that tells the TV which input to use (HDMI or component) for sound. Usually the HDMI connection will work automatically but if you connect cables to Audio L/R that may override the HDMI sound input.
Dec 07, 2009 | Televison & Video
Grainy apperance when HDMI components turnd on
HDMI cable change its sub standard.
Jul 08, 2009 | Televison & Video
Hdmi connection problem
it does do dvi-d for computer, but does not handle high-definition video. it does not have the same resolution.
Mar 14, 2009 | InFocus Proxima DP6155 Multimedia...
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Dvd installation
Why do you need to connect the rca cables when you get better sound through hdmi?
Feb 20, 2008 | Yamaha RX-V1800
Philips 52 In. LCD HDTV Logo
377 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
