Question about Yamaha RX-V1600 Receiver
Receiver shuts offs automatically
My receiver turns on ok but shuts off completely after about 30 seconds or so. what could be the problem?
  • 1 more comment
  • chris davis Jun 27, 2007
    I tried that idea, but no speakers wires are hooked up, and it still cuts off. thanks for the add
  • Anonymous Mar 31, 2008
    Yeppers i got the same problem, I just purchased the 1600 ran home alike a like a little kid with a new toy to connect it, wired everything up with bannan plugs, kicked in a dvd it worked great for 4 hours and it shut down first i thought it got to hot so i pulled it out of the rack and let it sit till the morning to cool off, woke next morning got dressed for work hit the button it stayed on for 3 minutes while i got dress and shut down, im lost and im gonna call the store at 9.30 when they open for a trade in, ill be back to let you know what happens next
  • tosick Jun 04, 2008
    I have the same problem. Ive secured all connections and my speakers are in wall. Since the problem has just surfaced after working fine for a couple of years, I think it may be something internal. I think it may be overheating. Any ideas?
Mine did same thing-when I put on my strongest reading glasses,I discovered ONE STRAND! of speaker cable was touching (-) speaker output terminal....felt like a fool....Worth taking a second look! attitudeRN@gmail.com
Posted on Jun 26, 2007
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Look at inside at capacitor and fuse but they seem ok. again once i turn it on, it would automatically shuts off after a second.
When a system shuts down after a few seconds it is the self protect circuit shutting down power to the outputs to prevent (further) damage. It may be caused by frayed speaker wires, bad speaker voice coils, or blown output transistors. First, turn off power and remove all speaker wires from the receiver. Turn it back on and see if the problem remains. If it works OK, inspect each speaker wire at both ends for loose strands and correct these. Then, hook up your speakers one at a time until the problem reappears. That speaker or its' wiring is your problem. For safety's sake. turn the receiver off before connecting each speaker. An accidental short of the output terminals can be disastrous (and expensive).
Apr 06, 2010 | Yamaha RX-V661 Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Receiver shuts off as soon as I turn it on
having the same problem. it doesn'T Shut off immediately. but after 30 seconds or if I turn the volume up, then it shuts off
Dec 05, 2009 | Denon Audio Players & Recorders
I have a sherwood RD-6108 receiver that shuts off after 30 sec. of use
This is the overload protection circuit. Make sure not alot of dust build up inside and make sure no speaker connections are touching. Most likely being that it a sherwood you will want to consider replacement.
Thank you,
Lee
May 27, 2009 | Sherwood RD-6108 Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Receiver shuts off at times
There is some leakage of DC voltage getting to the output section. DC voltage will cause the protection circuit to kick in and shut down the amp. This should be a relatively simple repair and cost about $15-$30 in parts plus the local labor rate.
Dan
Dec 14, 2007 | Yamaha RX-V992
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V1600 Receiver Logo
751 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
