Question about Microsoft Xbox 360 Console
E80 CODE WITH ONE RED LIGHT ON XBOX 360
My son has had his 360 since Oct 2007. A few weeks ago, he got one red light in the lower right quadrant and an E80 error. Everything I can find on the internet relates this issue to updating to the NXE. I also find postings mentioning the R6T3 resistor. The resistor has not been removed at any time and no downgrading has occurred on this box. The 360 was bought brand new, no refurb. I have contacted Microsoft but it is like talking to a wall.
Can anyone help?
  • 4 more comments
  • mewoods1959 Jan 18, 2009
    We will definitely give this a try. I'll let you know what happens. Thanks!
  • Anonymous Feb 04, 2009
    i had the error E80 what can i do?
  • redsoxsfan18 Feb 14, 2009
    how am i supposed to get to the system blade if it is in the erro code mode
  • Anonymous Feb 14, 2009
    console making a buzzing sound and freezing up
  • BBwcoJ4L Feb 25, 2009
    how do i get to the settings and all that if i cant leave the error screen, i been workin on this problem for almost 3 hours. this is bs. this is not a problem with the resistor, its a problem with a virus that comes with the NXE update. SO if no one can find a way to fix this, i say throw out your xbox and get a playstation. i stand by xbox cause it is a cool console but it has far to many problems that MS refuse's to aknowledge. playstation plays good, has a 7% failure rate and while xbox has 1 graphic processor(GPU) the ps3 has 8 GPU's. its so strong that they dont have to release a new console for another 15 years and they are currently working on Virtual Reality.
  • Tw33kIt May 25, 2009
    Make sure your A/V (or component) cables and power cable are connected properly. Take your hard drive off and turn the system on, then if it's fine turn it off, replace the HDD, and turn it on again.
    if that dont work try this
    --==Console Reset Codes==--
    Clear All Installed Game Updates and Console Cache
    1. Go to the "system" blade
    2. Select "memory"
    3. Press Y on the HD symbol
    4. Press X,X, Left Bumper, Right Bumper, X,X
    5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
    6. Select Yes
    Clear Any Failed system updates that cause the console to error.
    1. With the console off, press and hold the sync up button (the small white one)
    2. While holding the sync button press the power button to turn on the console
    3. Continue to hold the sync button until the Console has booted up completely.
    4. During the boot process the console should clear any failed updates, allowing you to use it normally.
    So i tried all of this bs and o0o guess what i cant get the e80 error off the the effin screen
  • 296 Answers
Hardware failure
  2. Select "memory"
  6. Select Yes
Posted on Jan 18, 2009
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
Got on red light,E74
An E74 error is when the lower-right quadrant of the ring piece indicator flashes red and displays an error message in multiple languages: "E74 System Error. Contact Xbox Customer Support". The error is caused when there's a video problem with the Xbox's hardware scaler chip being damaged. As of April 14, 2009, the E74 error is now covered by the three-year extended warranty.
Aug 09, 2009 | Microsoft Xbox 360 Console
One red light on xbox 360
One red light means either the hard drive isn't connected properly, or the video cable isn't connected properly, or is damaged.
Check the hard drive, and the video connection to ensure they're in there tight.
Mar 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 burning cds
Its laser burn. I have had this. Ask your son if he has tipped the xbox 360 with a game in it as that can cause this. If not the tabs that hold the game in place are broken causing the disc to 'wobble'. If you get the bottom right quadrant illuminate red then contact me personally at: sauldaedalus007@yahoo.co.uk
Dec 03, 2008 | Microsoft Xbox 360 Console
Xbox 360 - E 79 error code
1-800-4MY-Xbox
This is the # for Microsoft
Repair is prepaid and is free -if the warranty is still good-
The will tell you how long the xbox will be gone usually 1-2 weeks
They will give you xbox.com code to track the xbox
UPS code to track its progress and where it is at.
Hope this helps
Please rate my help//
Nov 28, 2008 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
6,321 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
