Question about Akai PDP4273M Television
No display, just winked out in middle of show
I bought this only last week, had it up and running, was in the middle of watching a show and the display just turned off. I tried turning it back on a couple times, nothing, only sound, i also tried unplugging for a while, nothing, no picture, only sound, no menu either. can anyone help?
  • o666 Aug 10, 2008
    have had the tv for a year and a half and the warranty is no longer in affect.
  • hardmanmusic Feb 17, 2009
    what 2 capacitors. I have the same problem took it apart and I cannot findany bad ones. I also have more of the same model and the inside is entirely different! found a pcb on ebay for 118 but I would rather try the capacitors 1st.
You need to replace two capacitors on the power board to get the display back.
Posted on Nov 28, 2008
Screen burned out, mine did the same thing after 2 and a half months, start the warranty process as soon as possible as it takes forever.
Posted on Sep 28, 2007
SOURCE:
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Feb 05, 2014 | Casio G-Shock World Time Analog Digital...
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Bought desperate house wives 6,there are two 5 discs.4 is missing,had complained last week .no answer
watch it on internet.. www.letmewatchthis.com.... category CLICK TV SHOW then search you favorite TV shows...
Apr 27, 2011 | Audio Players & Recorders
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
Hello, i purchased a Haurex Maestro watch last year. i believe that it is a mechanical watch but i've had issues with the watch stopping. i was wondering if someone would be able to assist and let me know...
i just bought one last week and having the same problem. I have an accutron automatic watch and once i get it started it will keep time for up to 48 hours w/ no movement. I think the haurex is poorly made and if i can't get it to run longer than 12 hrs( wichi is about how long it runs now) i will be returning it.
Feb 22, 2011 | Haurex Maestro Mechanical and Chrono Watch...
I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    I bought watch from Philippine airline last week , and when i arrived Sydney i found the strap is not attached as soon as i hold the watch the strap came off is there branch for your company i can call...
    mcdevito75 here, Even if you did find the company how can you show their fault in your watch??. Best bet, simply look for a small watch repair shop in your area for the repair.
    Aug 10, 2010 | Beverly Hills Polo Club #52055 Watch
    6 monts old quartz model vz03-dd 2 weeks ago hands stoped, after adj. runs fine now all stops , no hands movement, no display.
    Replace the battery. Does not matter watch is just 6 months old - battery was fitted long before you bought it.
    Jan 24, 2010 | Watches
    How can i recall multiple laps during a run?
    The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
    Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
    Televison & Video Logo
    233 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
