Question about Epson PictureMate Photo Printer
Wont read ink cartidrige
Bran new printer, used tempory cartidrige that came with when I got printer as a gift. just got new camera wanted to print pictures(of course needed new ink) replaced with new ink cartridge and now printer wont read. say Please insert cartridge is there somplace i can take it or send it to fix the problem?
The problem might be the cartridge sensor and or it's door sensor. Make sure the cartridge chip is clean (I wiped mine a couple of times with dry cotton swab and blew away any lints). Insert the cartridge and lock it, pushing and applying some pressure on it's right edge to make sure it (cartridge chip) makes good contact with the sensor (pin contacts) within the printer. Close the door and press firmly on the left edge of door access to ensures door magnet holds door closed allowing right door hinge extension to close sensor switch properly.
Posted on Jun 29, 2009
    Problem Solver:
  • 9 Answers
First try taking out the cartrage and try uninstalling the printer off your computer then reinstalling it. before putting in your cartrage make sure your computer detects it and your computer should tell you that it detcets no ink then try replacing it. if the problem consists make sure youave the right cartgae for that printer. Then check that nothing (paper, pen, anything) is stuck or jamming the computer blocking the cartage sensors,
Posted on Jan 17, 2009
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Polaroid p310 photo printer wont print brand new
HI!
can you read the instructions at the manual Brochure!? maybe you not set it properly. please read the manual to operate your printer verywell.
Nov 01, 2007 | Polaroid iZone 300 Digital Camera
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
It only prints light color ive replaced branw new
You need a new print head. Don't buy one, though. Phone Kodak (India) and get a new head. Or throw the stupid machine away. Kodak should be sued for producing such poor quality ****.
Jun 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Wont print black because it doesnt have color ink
So for now, you can change the print settings to only print in black.
Change the print properties/ colour to grayscale.
May 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Want to print with black ink only using Brother MFC-420CN
I see it's been a while since you posted your question but in case anyone else is wondering about this, I'll answer.  The information is not in the User's Guide booklet but in the Software User's Guide which should be available on your software disk, or you can view it here http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UsaEngSoft_C.pdf
Basically, you go to the advanced tab under the printing preferences and select grayscale.
Dec 17, 2008 | Brother MFC 420CN All-In-One InkJet...
Lexmark x3430 low ink warning
when you installed the new ink cartridge did you go into your program menu and find the lexmark solution center? If not, you have to go to the solution center, choose the maintenance menu and tell it you have installed the new ink cartridge. If you don't it will not recognize the new one.
Jun 23, 2008 | Lexmark X3470 All-In-One InkJet Printer
Helpppppppppp
Jan. 12/08
I have same printer. No manual. Guess it's too simple and the creators don't think general public need instructions! I am using a Canon S1 camera. My camera screen said to press the "SET" button to print the picture that I had on my camera screen. It worked for me!!! Good luck. I'm guessing printer only prints from a camera, hence it's portability.
Nov 09, 2007 | Lexmark Polaroid P310 Photo Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Epson PictureMate Photo Printer Logo
266 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
