Question about Netopia Cayman 3347W-Ent Wireless Router
Could you walk me thru connecting a Netopia 3347WG router
    Scholar:
  • 62 Answers
In the ATT region, they use PPPoE (in general, even if you have sticky static IPs)
plug in the router, turn it on, open Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
click on configure, then click on quickstart
type in your username (the emaill address from ATT like lc61544@att.net) and your password for your email address
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, you can open IE or firefox, whatever
and see if you're online (you should be)
spin
Posted on May 01, 2009
My network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
Mar 09, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Should you turn off the netopia 3347wg wireless modem?
Leave it on but set a security key, so that unauthorized people cannot get onto your network.
Sep 23, 2009 | Netopia 3346N-ENT Router (3346NENT)
I cant find my driver for my netopia 2247nwg wireless router.
You don't need a driver for the router. If you go to the netopia website, they will have directions to allow you to get into the box through your browser with step by step instructions. An alternative is to call your DSL provider. Their tech support should be able to walk you through all the steps. I hope that helps.
Sep 12, 2009 | Netopia 2247NWG-VGx Wireless Router...
Cannot get to router configuration screen
If you are using Internet Explorer, you must prepend http:// to the IP address to go there.
1) type http://192.168.1.254 into the browser window and you should go right there.
2) assuming that you are using the default configuration of the router, this should do the trick. Otherwise, you may have to manually place the laptop on the same network as the router.
Try #1 first, and see if that doesn't give you access.
I hope this helps.
Aug 18, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
I'm trying to set up a wireless network for the first time... can anyone walk me through it??
connect the Modem to the WAN or Internet port of the router then wired the computer to any LAN port of the router.
Open IE and type the IP address of the router
Login to the router
Example if its Dlink
IP is 192.168.0.1
user: admin
pass: none
If linksys: 192.168.1.1
user: none
pass: admin
Then run the setup wizard!
if you cant find the password click here:
www.routerpasswords.com
Apr 28, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
VPN connection - Client cannot connect
Hi mwells960
Theres alot of differnet things i could ask you, but im going to assume you're jsut setting up a basic VPN. That means that somebody is telecommuting to work and wants to hit the server at work.
That means you have a static ip at work, and your at home workers has whatever, a internet connection lets say. Im thinking DSL with ATT since its a netopia 3347N.
If the netopia has a gui interface, you cant vpn thru it. Its not a VPN router. Its a residential router that you're trying to make do too much.
The sad news is, you can't upgrade it to an Enterprise having firmware router anymore, netopia use to offer that, but when Motorolla bought them out last year, they did away with that nice little feature. For true VPN'ing with a router, first, go get a VPN router to start with.
Most people accomplish what you are doing by putting the netopia in to bridegemode, and then putting a VPN router like a linksys behind it.
spin
Apr 15, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
My router reads waiting for dsl
yes, youi can use as just a router, I use to do it myself, I had a netopia behind a linksys
but the netopia is actually a modem/router in 1.
you can also use as just a modem if you put it in bridge mode.
spin
Nov 12, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia Router - No Connection, Clicking
Yes, you need to swap the router out.
This is assuming you dont have the netopia in bridge mode with another device behind it.
spin
Jun 26, 2008 | Netopia 3346N-ENT Router (3346NENT)
How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia Cayman 3347W-Ent Wireless Router Logo
342 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
