Question about Frigidaire Affinity ATF7000ES Front Load Washer
My frigidaire refrigerator is broken
The ice dispencer will not shut off when the door is closed.At this time all i can do is turn my refrigerator off.
You have aproblem with your ice/water dispensor control.
3 parts; one or more may have problem.
1-Dispsnsor board control, 2- dispensor tochpad , 3-membrane connecting 1 to 2.
Posted on Mar 01, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Under the cap of the top end of your freezer door is a plug. Unplug it. If this is helpful, please post as such. There is more to look at. Please use premium chat so I can help you while you help me. TY
Posted on Jan 17, 2009
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
The ice maker keeps freezing up where the ice comes out of the door on my Frigidaire Refrigerator.
The ice door is probably not shutting tight allowing air in which frost up the door. Inspect the hinges on the ice door. It could be a broken bracket or hinge or the solenoid which operates the door may not be closing it all the way. Remove the dispenser cover by gently prying it off starting at the bottom and then remove the screws to access the other parts.
Dec 22, 2009 | Frigidaire Refrigerators
Door inside the ice dispencer sticks open. have to push it close
Sounds like the clear plastic door guide on the ice dispensor arm , is broken loose , holding the door , keeping it from closing . If this is the problem , it just snaps on . If a piece is broken from the guide , pt # 985866 is usually the part .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker does not dispence Ice.
Does the water dispense? A lot of side by sides require the door switch to be closed completly before any of the freezer door functions will work. Try making sure the door switch is closed.
Jun 17, 2009 | Frigidaire FRS26H5AS Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Ice Flap on my LG LSC26905TT will not close after ice dispences
ran into an LG tech today with identical problem and was told to replace a solenoid that closes the door flap.
Mar 04, 2008 | LG LSC26905TT Side by Side Refrigerator
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
