Question about Microsoft Xbox 360 Console
Xbox reads films but not game discs
HI, my xbox plays films and games stored on hard drive but will not not read game disks. Can you help please
  • UNSC_SIERRA1 Jan 18, 2009
    acavo de comprar mi xbox noda imagen pero devesencuando dala imagen pero luego se quita
  • 296 Answers
Try cleaning the laser lens with a disc cleaner
Posted on Jan 18, 2009
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
Jul 18, 2011 | Microsoft Xbox 360 Console
The game freezes when your playing new goblin
Hi There.
The first thing to check is the disk, are there any visible scratches on the disk ? If so see if you can get your disk resurfaced, many game and tech stores now offer this at a relatively small cost.
Another solution is to borrow the same disk from a friend (or rent from a store) and install it to the hard drive of your xbox, you will still need your disk to play the game but your xbox will be loading the data off your hard drive.
To understand this problem you have to understand that it occurs when your xbox can't read the file you need to play that aspect of the game for you this seems to be the new goblin character, the two remedies above will solve this issue.
Regards.
Lawrence Ahern
Please Vote
Jul 04, 2011 | Microsoft XBox 360 Spiderman 3
It seems the xbox 360 wont read the disc... every time i go to play a game alls it says is open tray... and the game never loads..
I have had the same issue and it turned out to be my hard drive. If you take the hard drive off the xbox, it will read the disk right? Then replace hard drive and the problem comes back? I stopped using the hard drive and I now use the little save cards that go into the front of the xbox. hope this helps.
Oct 22, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
5 minutes playing online keep giving me error message that the disk is dirty. i know it's not i played the same cd to another xbox console it's fine. what should i do or what's the problem...
Hi chrisastig
try to save the game you are playing to the hard drive so as to play from hard drive & not from the disk ! this is assuming you have enuf room on ur hard drive to copy the game to ??
You will still need to put the game in (even when playing from hard drive) but i find if its a game you play a lot its well worth doing as it saves on the disc drive/disc spinning whilst playing :-)
saves on overall usage of the xbox too !
If its ok reading the disc for the first 5 mins of usage it should be ok to copy to the hard drive to play from.
If there is a fault with the disc itself it will tell you when you try to copy it to the hard drive & if this is the case (& its a game you like/play a lot??) then try to borrow a copy just to put on ur hard drive only & use ur damaged disc as the 'required even if playing from hard drive' notification to the xbox that you do own the original copy !
Damaged discs are usually ok for 'playing from hard drive' as the information the xbox requires is very little but enuf for it to allow you to play the game (from the hard drive)
You will find it a lot quieter whilst playing anyway ! i think so !
hope this helps :-)
please remember thumbs up :-)
p.s. refer to ur xbox user manual or drop me a mail if you have any problems doing any of the above ??
Feb 14, 2010 | Microsoft Xbox 360 Console
Assassin's Creed 2 won't load on Xbox 360
Sounds like your cd drive is not reading the discs properly. If that's not the problem, then you have a scratched disc on your hands.
Do what I did. Go to sellitbroken.com and sell your scratched/non-working game to them. They will give you good money for it.
Jan 01, 2010 | Ubi Soft Entertainment Assassin's Creed...
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
CoD4 disc won't read.
how many times have you tried to play the disc?
the 360 is prone to many disc read errors, and most of the time if you just keep trying to play the disc it will work. xbox recognized the problem, and with the new dashboard update you can install games to your hard drive which minimizes the time the disk is spinning, which in turn minimizes disk read errors.
if it doesn't play, I would deffinetly try getting a new copy before sending in the console. getting a new copy is just a trip to the store, sending in the console will take a month.
Jan 15, 2009 | Microsoft Xbox 360 Console
Wont play
same here when ever i put in a brand new game just opened into my brand new xbox it reads for 5 seconds and then says sorry please clean disc and it was clean brand new.
Jun 02, 2008 | Microsoft Xbox 360 Console
Xbox doesnt read disks
If you have a Hard Disk Drive or Memory attached to the console, turn the console off and remove the Hard Disk Drive (HDD) unit and any attached Memory Unit (MU), then switch on your console and try the disc again. If this seems to resolve the issue, turn off your console, attach the HDD and MU again, and then delete any saved games for the game that is causing problems.
Note If it is possible to do so, save the games to a separate MU.
To find out how to remove and connect the Hard Disk Drive from your console, see the following Microsoft Knowledge Base article:
906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive
Don't forget to rate!
Feb 28, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
87 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
