Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint first edition few 12p,not working
Hi there i have the hotpoint first edition few 12p washing machine,and it is now not working,what is happening is i am pressing the start button so the active button red light comes on ,but also the red light keeps flashing on & off on the door locked sighn and i can also still undo the door when in active mode,,could this be the door lock mechanism causing this problem please ? also if i have owned the washing machine for about 3 years now,is it true that hotpoint parts are all free & covered up to 5 years?
  • forduk2008 Jan 17, 2009
    can i have an anwser please?
    thanks for reply,but not anwser i am looking for,i press the start button,as normal then red active button comes on which is normal,then machine usually starts working,but also the ( door locked ) red light keeps flashing on & off & there is no response at all of the machine working i can still open the door which is not normal,could this be that maybe someone in my household could of accidently forced the door open why machine was still on wash cycle,which has maybe damaged the door lock mechanism ? please i hope some can help ? i dont have the money for a call out charge of about £80 ,i need to know if it could be the door lock mechanism ?? please help
    Problem Solver:
  • 14 Answers
Have you tryed pushing the door in. mine did that and thats what i did and it worked hope this help you
Posted on May 12, 2009
    Problem Solver:
  • 5 Answers
Parts are free but a call out charge is made approx £80.00
Posted on Jan 17, 2009
Hotpoint first edition FEW 10P change dram or bearing,terrible noise
yep bearings are gone for sure so common with front loaders if can buy a top loader so much better value for money than paying for bearing jobs every few years.
Jan 05, 2011 | Hotpoint First Edition FEW10P Front Load...
Hi, I need a repair manuel for a Hotpoint wm 53 first edition 1200 please. PDF download would be great. Many thanks.
You willnot be able to purchase a repair manual for your washer, as they are usually not available to the public to buy.
Try going to a repair forum, there are quite a few on the net, and they are very helpful.
Oct 21, 2010 | Hotpoint Washing Machines
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
Bad smell coming from washing machine
It probably is related to your drain outlet, depending on the set-up, I would suggest you remove drain hose and clean the place where the drain hose enters the drain system, if possible, clean all associated pipework
Please rate my solution.
Thanks.
Sep 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Washing machine not spinning at the end of cycle
if the dial is moving round as normal and the machine is filling and emptyin change the motor brushes this will cure the problem
Dec 20, 2008 | Hotpoint First Edition FEW12 Front Load...
No instructions
Go to:
www.hotoint.co.uk.
Scroll down and click on www.hotpoint.co.uk.
Click on after sales and then click on down load instruction books, type your model number in and you can save it to your hard drive, or print it off.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint FEW 12
hi there i have had this problem before and found out it was due to to much weight in washing machine? or maybe your drumbelt may be loose which is connected to drum at the back on the inside? hope this helps
Nov 04, 2008 | Hotpoint First Edition FEW12 Front Load...
Ginko
Hi, We have just put our Hotpoint few 12 backtogether. If you tell me exactly what you need to know I will take the front panel off and let you know. contact me on suewade5@yahoo.co.uk
Aug 17, 2008 | Hotpoint First Edition FEW12 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
278 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
