Question about Toshiba MD20FP3 Combo
Accessing TV Menu withough original remote
I have a Toshiba MD20FP3 w/o the original remote. How can I acccess the TV menu from the set itself. I tried buying a universal remote, but none of the codes access the menu function. I need to switch the antennae from "Air" to "Cable"
  • nickfj21 Jan 17, 2009
    Thanks.....Toshiba must have been looking to make extra money down the road on Remote replacements....who makes a tv w/o a menu button on TV itself anyways....The TV is in a spare bedroom that is rarely used for guest - not paying $20 for a replacement remote for a TV that's never used. Oh well....
  • glpeirce Mar 22, 2009
    Same model, same problem. NEED TO GET TO MENU.
    IS THERE ANY COMBINATION OF BUTTONS TO PUSH ON THE FRONT OF THE TV?
    Genius:
  • 1,199 Answers
No you need the remote ! and even most universals will not do that function for you either!
You can order an orignal replacment remote from www.remotes.com and that will let you access all of the tvs functions!
I hope I was of big help!
Please rate my FREE response!
Thank You!
Posted on Jan 17, 2009
Access menu without remote on Toshiba 27AF44
You can follow the option of searching the internet for any of several suppliers of OEM replacement remotes. The problem with universal remotes is that not all functions of the OEM remote are replicated.
Dec 19, 2013 | Toshiba 27AF44 27" TV
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Televison & Video
I lost my Original Toshiba remote control for my TV and I need to do a channel scan that is in the setup menu, but the TV itself doesn't have a setup button to push to access the scan function, How...
You can buy a universal remote, any best buy will carry one, I have even found cheap ones at dollar tree or dollarama. They come with a manual with the codes for the make of your TV just follow the coding instructions until you find the one that will operate your TV.
Good luck
Jan 19, 2018 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
I have a Toshiba 27AF45 and a RC64 remote control which is not what comes with the TV. It works ok but I cannot figure out how to turn on the closed captioning feature. When I enable the menu I do not see...
Unfortunately, TVs don't always work with universal remotes. The original remote probably had a button to control the captions, and there may not be any other way to access those settings. If you can't find caption control settings using the on-screen menu, you are out of luck. The only options then are to try another brand or model of universal remote that may have a button which will work, or to locate a replacement original remote control.
Jun 21, 2011 | Toshiba 27AF45 27" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
No control and the picture is too dark
Not sure what you mean by no control?
Brightness settings on any TV made since the early to mid 90's (besides tiny cheap B&W TVs) will have the settings in an on-screen menu. Sometimes the menu is accessible through buttons on the TV itself, but always accessible through the remote control. If your TV does not have the ability to get to the settings menu from the TV controls itself, you will need the original (or compatible) remote control for the set, there is no other option.
It could also be that the set is just dying; it's an older set, and certainly would be a possibility.
Nov 14, 2009 | Sharp 25N-S100 25" TV
Need Remote Control For 1992 RCA TV Set
There should be access to the menu system from the panel controls. Either a menu button or pressing a combination of buttons for a certain period of time to access the menu.
Oct 06, 2017 | RCA F27450 27" TV
Accessing menu without a remote
You will need to get an original replacement remote or the original to access the menu. An original replacement remote for this TV set is not cheap! You can see what you need here
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=SDP50A5K&brand_pn=PIONEER_SDP50A5K&mode=large&uid=11944400246090
Good Luck
Nov 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Toshiba MD20FP3 Combo Logo
239 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
