Question about Uniden Cordless Phone
A MESSAGE KEEPS REPEATING TO PRESS REVIEW BUTTON.
I RESET THE DAY, TIME AND MINTUES AND IT STILL REPEATS TO PRESS THE REVIEW BUTTON TO SET TIME AND DATE. I HAVE A 40 CHANNEL 2.4 GHZ TELEPHONE ANSEWERING SYSTEM # 27996 2 HANDSETS.
  • irisl Jan 19, 2009
    that doesn't work it only repeats each day until you stop on the day it is.
Try pressing then releasing the day/check button
Posted on Jan 17, 2009
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
Instructions for m450 telstra answering machine. How do I change date and time please
To review the current set day and time, press the Stop button, the current
set day and time will be read back.
To change the day and time, press and hold the Stop button. The day will be
read back. To change the day, press the <Skip or Skip> button. Press the
Stop button to set the day, which will be read back.
Next the hour will be read back. To change the hour press the <Skip or
Skip> buttons. Press the Stop button to set the selected hour.
Next the minutes will read back. To change the minutes press the <Skip or
Skip> buttons. Press the Stop button to finalise the whole setting.
here are full instructions for operating your device:
http://www.freewebs.com/aa2001/M450%20Telstra_CPE_Userguide_Digital_answering_machine_M450.pdf
Sep 20, 2011 | Office Equipment & Supplies
My Model # is 27957FE 1-A Dont know how to reset
To set the time and date, start at the base unit. Then press the Flash/Program until Set Day appears on the display. Press the Review or Next button to select the day of the week. Then press Flash/Program again until SetTime appears in the display. Type in the time (hour (two digits) then minute (again two digits)) with the keypad number buttons. Then press Review or Next to select AM/PM. Press Flash/Program to store the information.
Please note that if you have Caller ID, the time and day transmitted with the caller ID information from your phone company will override the day and time you have set.
The manual is available here: http://www.home-electronics.net/USER-GUIDES/27957_DOM_ES_CL_IB.pdf . See page 15 for this.
I hope this helps.
Jun 01, 2011 | Thomson GE-28115FE1 Cordless Phone
Hey i;m hector : MY PROBLEM / 7 DAYS SETUP NO WORK ; ( ej: TIME ON 8.00PM- TIME OFF 5.00AM( SEME DAYS MONDAY TO SUNDAYS?
Hi Hector.
You posted under ET171C8.
You have the timer in front of you, and whole manual cannot be repeated. So there are two options
1) Free option: Add a comment and say specifically where the programming is tricky. If you don't understand the buttons, or if display doesn't show, or if you can't find all days by pushing day button, or if you can't find the am pm choice.
2) Pay for fixya expert to walk you through each step via e-mail.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et171c%20-%20english.ashx
http://www.intermatic.com/products/timers/electronic%20time%20switches/7%20day%2030%20amp.aspx
If display shows, then battery is correctly installed.
Instructions copied from manual:
1) RESET TIME SWITCH: Press the recessed RESET switch to reset the
microprocessor and delete any set point information which has been
programmed. NOTE: DO NOT press RESET after programming has
begun or you will lose all of your program information.
2) TO SET TIME AND DAY OF WEEK: Place the three position selector
in PROGRAM and the two position selector in CLK mode. Press the
HOUR, MINUTE and DAY buttons individually to select the current time
of day (12 hour AM/PM repeating) and the day of the week. Day 1 is
Sunday, day 2 is Monday, etc.
3) TO PROGRAM SET POINTS: Select PROGRAM mode with the three
position selector and OUTPUT mode with the two position selector.
Press the HOUR and MINUTE buttons separately to program the first set point time desired.
Press the DAY button to select the day the event is to occur.
Press the ON/OFF button to select an ON or OFF set point.
Press the ENTER button to enter that set point for the selected day.
Note that the ON or OFF indicator stops flashing only after pressing ENTER. If this set point is to occur for other days of the week, simply press the DAY button to select the next day then ENTER. Repeat for any additional days. Note that this allows you to utilize one set point for
any or all days of the week.
Then set timer to AUTO for programs to operate
Apr 26, 2011 | Intermatic ET171C8 Electronic Timer
I have model 0155671 but it doesnt look like the model online mine has four buttons across set time plus minus next riw is rnd ctd bottom is manual i dont understand when it says select 12 or 24...
A) 12-24 hour choice >> just use the 24 hour display.
That gives you day and night hours
I don't know why these companies offer 12hr-24hr option on timers.
B) Military time vs Regular time (military time does not use am and pm)
1 1am
2 2am
7 7am
11 11am
12 12noon
13 1pm
14 2pm
20 8pm
23 11pm
24 12midnight
C) Utilitec 0155671 is same as Woods 59377
Before Woods made 59377, they made 49566 (which is also called TD1101 and TD1300)
I think you have Woods 49566
Manual for Woods 49566:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Add a comment at any time.
D) How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
1) Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
2) Program review:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
3) Program the timer:
ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not hold set button down as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you will set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
4) Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 05, 2010 | Hardware & Accessories
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
Jan 24, 2009 | Casio Sea-Pathfinder SPF40-T Wrist Watch
How do I set the Prerecorded Greeting?
Press delete while reviewing your announcement.The system will use the prerecorded message until you record a new one.
Setting the Clock
NOTE: A flashing
"CL"
in the message window indicates that you must set the correct
day and time at the base unit.
1.
Press the TIME button. The system announces the time and day of the week,
followed by
"To set day and time, press TIME/SET."
2.Press the TIME
button. The system announces the day.
3.Press the CHANGE
button repeatedly until the system announces the correct day.
4.Press the
TIME
button to save the new setting. The system announces the setting.
5.Press the
CHANGE
button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6.Press the
TIME
nnounces the minute.
7.Press
CHANGE
to advance the minutes one at a time. ­OR­ Press and hold the
CHANGE
button to advance the minutes in increments of 10.
8.Press the
TIME
button to save the new setting. The system announces the year.
9.Press CHANGE
to advance the year one at a time. ­OR­ Press and hold
CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME
. The system announces the clock setting
Aug 12, 2008 | Motorola Mobility E51 MD7161-2 Twin...
Motorola MD4260
I had the same problem.
Here is the solution that I received from Motorola tech support:
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
Nov 22, 2007 | Motorola Mobility MD4260-2 Twin Cordless...
When simeone calls, it won't record their message
Try this..
Press "menu" button until you hear  "Change Announce only" Press "select" button until you hear  "off" Press "Time/Set" button
Apr 20, 2007 | AT&T 9353 Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
