Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
How to disassemble case.
I've got one with water damage and need to get inside. I've removed all the visible screws on the back panel, but top portion is still held in place solidly. What is the trick to removing the back panel?
  • 594 Answers
Pry the metal spring clip in the base of the hotshow toward the rear of the camera with a pocketknife, itll pop out and there will be 4 small screws under there, Ill put a buck on that bet. The hotshoe needs some good anchors to support some beefy flash units so it has screws to hold it down, metal hotshoe to metal chassis.
Posted on Feb 07, 2008
  • Steven Wander
    Steven Wander Feb 07, 2008
    The 4 screws are under the hotshoe on my C-5050 too and there are some screws under the flash memory door too. There was a total of 11 screws on the C-5050, dont forget the screws around the tripod socket. oh yeah and if you want to part it out, give me a ring...
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
How can i disassemble a jmc7000adw
Although most open via a screw at the top or left side of the control panel.
Some require the cabinet / casing to be removed. If there is no visible screws at the top or sides of the control panel. Then the casing will need to be removed.
Mar 27, 2012 | Jenn-Air JMC7000 Microwave Oven
Disassembly of the tivoli table top radio
After removing the 6 screw, gently slide the front panel out of the box. Now disconnect the little 2-way connector with a black and white wires: it should be the more tight cable between the front cover you have just removed and the rear panel.
Now slip-on your fingers in the box and push the rear panel up to slide it off the box, so that you can turn gently the front panel, pass it through the box and get the electronic completely apart from the wooden case.
Mar 16, 2012 | Tivoli Kloss Model One AM/FM Radio
Dryer quit running during cycle. Clothes were hot. Dryer will not start. Light works when door open & buzzer works when pushed.
Limit switch opening - most likely due to an airflow problem. Lint buildup may not be visible to you without some disassembly of the dryer. The top should fold back by removing two screws that hold the front down. The front panel should come off by removing two screws inside and possibly a few pressure clips. Check for lint buildup on the blower intake and beneath the lint filter.
Oct 28, 2010 | Kenmore Dryers
Need to Remove the top of a Maytag LAT7300AAW washer
if its a top load,you need to remove the front panel first by removing screws near floor of front panel,then the top screws are visible at the underside of the front of top cover
Mar 12, 2010 | Washing Machines
I want to disassemble to clean around the top of the basket. How do I disassemble this washer?
These instructions are for Kenmore top load machines. Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the front of the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the control panel corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the case top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
Sep 13, 2009 | Kenmore Washing Machines
Water leaking from kenmore top load washer
If the plastic piece you are refering to is the pump, yes it is replaceable. The pump is on the front of the motor on the under side of the machine. It is located front and center and has a history of wearing the case from the inside out. The part is available at www.sears.com under the parts direct tab. You will need your model number to find your machine and then the replacement pump. The model number is three digits a decimal and the remanider of the number, aka. 110.5555555. The model mumber is usually under the lid, on a top loader. Instructions are not included with the pump, so if needed here they are./// This will remove the case.///
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or two hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward and remove the case. ///There are two clips holding pump to the motor. Remove the clips and pull the pump forward. There may be some residule water in the hoses, be prepared, disconnect the hoses and the pump is out. Reverse the procedure to install the new pump and you're in the laundry business again. Good luck. Need help? I'm here. Just post a response and I'll get an email from Fixya.
Aug 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
E20, slow to drain frigidaire atf7000fs
probably has something stuck in the electric drain pump happens alot on frigidaire washers it is accessable after removing front lower acess panel tilt washer back after pulling it from the wall the drain pump will be just right of center at the front use a pan to catch any water that will come out you can either remove the 2 drain hoses to clear obstruction or you can unscrew pump motor from pump body
Good Luck!!
Thanks.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the back?
Dryers do not open from the back
the screws removed secure parts to the inside of the case
carefully replace them.
to opent the front of the dryer
unplg dryer
type I: maytag:kenmore stackable:speedqueen:
  • remove 2 screws from bottom of front panel, swing front panel out at bottom and unhook from dop
  • remove door switch wires from switch
  • remove front panel set aside
type II: Kenmore:whirlpool:ge:frigidaire
  • remove lint filter
  • remove 2 screws in lint filter holder
  • with putty knife or other blunt blade
    depress spring catches at corners of top cover
  • lift top cover at front
  • remove 1screw each side 1/3 way down
dryer internals are exposed and easily repairable
examine back panel to ensure that nothing is detached from screw removal
assemble in reverse order
Note:
while the dryer is disassembled, examine felts rollers and glides for wear, most common cause of belt breakage, if there is any wear, replace.
examine fan, fan housing and ducting for lint that got past the filter screen.
Oct 28, 2008 | Dryers
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
314 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
