Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Food freezing in some parts of refrgerator
I have an Admiral refrigerator Mod. HMG19124, circa 1996, with freezer on top. On the lowest shelf of the refrgerator, to the right, we're having a problem with food freezing. It's only in this section & all the way to the right. I've played with the temperature settings in both freezer and refrigerator, all to no avail. Anyone have any suggestions? Thanks.
  • Larry Schneider Jun 25, 2007
    Thanks, I'll check it out tonight.
  • 35 Answers
This problem has to do with airflow.make sure that all vents are free.
Posted on Jun 25, 2007
SOURCE:
My Admiral freezer is cold but not freezing. The fridge seems fine but food in the freezer is thawing.
See if the coil is clean, if not, vacuum and brush the coil clean.
That should make diagnosis much easier.
Jan 09, 2011 | Maytag Admiral Top-Freezer Refrigerator
Admiral ATF1910DRW refrigerator. The refrigerator
hi there,
there seems to be a technical error. call your repairman to have him take a look at the inside wiring before your food gets spoiled even more.
Jun 11, 2010 | Refrigerators
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing...
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Jun 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Need top shelf for admiral refrigerator
Click on this link to see if they have what you were looking for.
http://www.repairclinic.com/Appliance-Parts?s=t-HMG211380-%3d%3dc270
Your refrigerator stopped being built more than 6 years ago, so some items are no longer available.
May 02, 2009 | Refrigerators
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
244 people viewed this question
Top Admiral Refrigerators Experts
Ekse
jasbo
jasbo
john h
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
