Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Fixya My frezer is working but fridge side is not.It iced over and I used a hair drier to defrost the ice. Is the fridge cooled by the frezer side ,threw the holes in the bottom left back side.Their seems to be no fan blowing in the frige side. What is up with this! The hole enters the coils about 2x2 hole. The paper work is not real clear on operation of this apliance. I have been trouble shooting it my self. It will be a month before I can get a technition.
I called a repair man. I was charged $150.00 . It was the box at the botom left side of the fridge,under fridge. It's fixed .It took about 5min. to replace it. I could have done it my self. Reading FixYa pointed me in the right direction. Reading postings on FixYa! What a great place to recieve info! I am not sure what the part cost, if you were to install it your self. Not a big job it has two screws that holds it in place. I had to work, was in a bind for repair man. It was worth the $150.00 to have my food back in the fridge.
Posted on Jan 21, 2009
Cooling problem-set fridge to 34 will not go down past 50 took bottom off of rear of fridge vaccumed all of dust out unpluged for over 9 mins and pluged back in fan took a while to com on infront of...
Hello Sir Randy!!!
Welcome to fixya..
I remember that kind of symptoms happens before on my side by side ref..Try to check the coil on refrigerator side if it is iced up ..
Take this steps on how to:
  1. Open the refrigerator side.
  2. Remove the 11 screws on it..
  3. Get the hair drier..
  4. use the hair drier to slowly melt the iced behind the cover.
Note: If you pull too hard and or too soon you'll break the Styrofoam ducting that has to be around the coil. then make sure that the drain line is clear reassemble..
Hope it helps..Thank you for using fixya and choosing my service.
Feb 24, 2012 | Samsung RS265LABP Side by Side...
My whirlpool fridge is not working, the freezer is working, I can't understand it. The thermostat inside the fridge seems to be okay, inside the fridge is not even cold. Can you help me. My fridge...
Your cooling comes from the freezer side through cooling tubes to the refrigerator side.
The first thing is to make sure that the evaporator fan is working, because that will blow the cold air into the refrigerator side. If it is working then you probably have an ice build up around the evaporator. You will need to remove the inner rear panel of the freezer to check it.
If there is a lot of ice on the evaporator fins then your defrost circuit is not working. But if you manually defrost the freezer (a hair dryer will speed it up) and make sure the cooling tubes are clean of ice (can feel the air from the hair dryer on refrigerator side) then you will have anywhere from a few days to a few weeks before the ice build up returns.
So you should troubleshoot your defrost circuit and get the parts on order to be ready for the next time.
Jul 15, 2011 | Whirlpool Refrigerators
Freezer not that cold. very noisy indeed, lots of thick ice inside. should i take off the panel behind the freezer drawers, to let ice there defrost?
Yes, It needs a defrost. You will have to take out all the food, unplug it and remove all the shelves and or drawers. Remove the back panel to gain access to the evaporator coil, (make sure you have the proper screw driver or socket first). You will need some towels and a hair drier. Once inside to the coil/fan area, start with your hair drier and melt all the frost/ice out as quickly as you can. Once all is done, start looking for any wires that look out of place or burnt. Your fridge has a defrost timer and a defrost termination switch that is mounted to the coil. Look for a round metal switch that should be clipped on to one of the coils tubes. This much frost/ice build up is due to ether a bad door seal, or the fridge is not defrosting itself proper. Check all this and then put the rear panels back on. clean up the mess. Plug it back in and start it up. You will want to be sure it is cooling ok before you put all your food back in. So put a cup of water on one of the shelves and check it in about hours to see if it has started to freeze. Hope this helps Fixya up.
Apr 02, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frezer keeps frezzing
If the freezer is icing up your defrost timer or the heating element may be bad. If the fridge doesnt go into defrost mode you will get frost on the back of th freezer and ice will freeze up on the coils eventually it will not cool the fridge side very well at all. If there is an ice block let me know also is the fan in the freezer running?
Aug 15, 2010 | GE Refrigerators
JUST THIS MORNING NOTICED WATER LEAKING FROM ICE MACHINE. AFTER CHECKING THINGS OUT LOOKS LIKE NEITHER REF OR FREEZER ARE COOLING, THE FAN IS RUNNING ? PLEASE & THANKS
Hi!!
Most likely the evaporator in the back of the freezer, behind the fan, is all iced up. You need to unplug the fridge and let it defrost, you can remove the cover and use a heat gun or hair drier to make defrosting faster.
Once it is defrosted, plug unit back on and lower the freezer temp. by one click.
Don't forget to rate this post. Good Luck!!
Jul 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Fridge section not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 05, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice maker not working
You will have to pull the ice maker out, defrost fridge or use a hair drier to defrost all parts in the freezer. then replace ice maker
Jan 21, 2009 | Sub-Zero 611 / O Bottom Freezer...
How do I get water line to ice maker defrosted?
you will have to remove the Ice maker and the use either a hair drier or shop vac the blow air onto the line unit it thaws. Have a Merry Christmas and thanks for using FixYa.
Dec 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice is building up on the back wall of fridge
Option 1 defrost fridge manually by switching off power for 24 hours, allowing built up ice & frost to melt.
Option 2 Switch off mains power and using a hair drier blow hot air into the freezer supply vents. This shuold shift the ice in a couple of hours
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
110 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
