Question about Epson Perfection V200 Flatbed Scanner
Filmy appearance and spots on the underneath of glass
The underneath side of the glass on my scanner has a whitish filmy appearance.  It started out as a small perfect circular spot.  Now, it is in a much larger area, and has the appearance of a dirty window that needs cleaned.  However, this is on the underneath side and I can't get to it. (I assume the glass is not removable).  Does this have to do with the mercury light bulb or something?  It is resulting in poor scans, as it shows up on the photos I scan.
  • dhecke Feb 01, 2009
    I have the same problem. Hope someone will help us!
  • dayirmiter Feb 07, 2009
    http://www.fixya.com/support/t1554094-fi...
    I recently bought a refurbished Epson V200 scanner. It arrived with the filmy blotches on the underside of the glass described by foxqueisser. I have read elsewhere that this film can be produced by fumes emitted from printed circuit boards, which are mostly isolated from the box in which the scanhead sits, but that this box sometimes has small holes in it for one (bad) design reason or another.
    I asked for a replacement of the first V200 and have since received two, both with the same problem. In all three cases the film appears on the right half of the scanning surface (the upper half of the scanned image). This corresponds to the area to the right of where the scanhead sits when the machine is idle. My guess is this position of the scanhead creates a relatively enclosed space in which the circuit board fumes accumulate.
    It might be possible to clean this film off the underside of the glass but it is not obvious how the user might get the top side of the scanhead box off so as to access it - though presumably the techs in the refurbishing deparment should be able to.
    I am pretty disgusted that they keep sending these functionally defective machines out to customers. Refurbs are supposed to be functionally sound with possible cosmetic flaws only. Obviously the condition of the scanbed glass is pretty fundamental to the function of a scanner!
    If somebody figures out how to take the scanner case top off, that would be a help to those who have bought these machines new and seen the problem develop over time. But if you're considering buying a refurb of this Epson model, save yourself the bother and don't.
Today I opened my V200 without much problems. First unscrew the two screws under the lid. Then turn the V200 upside down. Lift the base plate up, gently, beginning at the back (a little twisting is needed). Take care not to force anything. It took me 10 minutes. Fold everything open like a suitcase, then clean the glass inside...
To close again start with the front (sort of click system)
Posted on Feb 22, 2009
  • 4 Answers
Wow, thanks Mythos 2! I'd taken those screws out and separated the top and bottom of the case at one end but the other end, near the control buttons, remained so tight I was afraid there might be another screw down there I couldn't see, perhaps hidden under the rubber foot on the bottom. So thanks for your persistence and courage in blazing the trail on this and for sharing your results with the rest of us. In the same spirit I will elaborate below my observations in following your lead.
Something that will make the whole process easier - especially the glass cleaning - is to separate the cover from the top of the scanner box. Place the scanner upright with its back (the side with the USB and power cable sockets) facing you. Open the cover to straight up vertical and position yourself so you can look down its inner surface. Observe the flat piece of plastic that acts as a hinge between the cover and the back edge of the scanbed. There are two round posts about the size of a pencil lead extending to the left and right from the bottom edge of the plastic hinge. These posts are the only things by which the cover is held to the scanbed and they slide up and down in a groove. At the top of this groove are lips that prevent the posts from being pulled straight up and out. Pull up on the right edge of the cover so that the right post is at the top of the groove while the left post remains at the bottom. Notice the indentation in the left retaining lip. This happens to be just the thickness of the hinge. Push the left side of the hinge into that indentation and you will find the right post now can be pulled up past its retaining lip. Voila, the cover is off! (Do notice there remains a short cable connecting the cover to the scanbed.) Remove the two screws to the left and right of the hinge groove and you're ready to take off the top of the scan bed.
I started with turning the scanner upside down, as suggested by Mythos 2, but was concerned about the scanhead flopping down at one end when I pulled up the base plate, to which it is attached. So here's an alternative.
Leaving the scanner upright, turn it counterclockwise ninety degrees so that now the control button edge is closest to you and the back of the box is to your right. Starting in the upper right corner, gently separate the top of the box from the bottom. As the top comes up, angle it a bit to the left and the upper left corner should also come loose. Along the front edge of the scanner box bottom are four half-inch wide posts, each with a rectangular hollow into which fits a corresponding tab on the top. The tabs extend horizontally in toward the center of the scanbed and have slight vertical protrusions that hook onto similar protrusions in the hollows of the posts. Angling the top a little to the left will free the first couple of these tabs.
The tightest fit between the top and bottom is in the corner nearest the control buttons, so leave that for last; it will come loose much more easily once the other three corners are free. Assuming the scanner is still in the same position relative to you, both the upper right and upper left corners should be loose. Maintaining some upward pressure on the top to keep it separated from the bottom, move down the left side (the front side of the scanner) gently pulling the edge of the top out and/or pushing the edge of the bottom in. As Mythos 2 has said, don't force anything. With a little patience, this technique will free the other two tabs along the left side. With the other three corners free, the corner nearest the control buttons will come loose with an audible click.
For glass cleaning I favor the old standby: a tablespoon of vinegar in a cup of water. Wipe this solution sparingly onto the glass with a soft cloth (you don't want to get any liquid under the edges) and dry by rubbinb in a circular motion with crumpled newspaper.
When your glass is clean and you're ready to put the top back on, start by fitting the tabs along the left edge into the hollow posts. Once these are snugly in place the right edge will pop back into position with a satisfying click. Replace the cover in a manner similar to the way you removed it, and you're done! Thanks again to Mythos 2 for leading he way here. :-)
Posted on Feb 23, 2009
  • Aingon Atelia Feb 10, 2013
    Great writeup! Works for the Epson Perfection V100 Photo scanner as well, exactly as you said. Thanks!
When I use the scanner, an unsightly thin black line appears on the right side every page. How do I get rid of that black line? Please help! Thanks.
Clean the adf scanner glass (the slit of glass on the left side). All it takes is one spot to cause a vertical line through page
Nov 16, 2015 | Canon PIXMA MX310 All-In-One Printer
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
There is Dark spots on paper when a photocopy is done
Most likely there is something on the glass or something ie: dust underneath the glass that gets in the way of the scanner and the paper(dots) or on the scanner itself(streak). I have heard many times that photocopy machines in cvs/wall greens, any kind of commercial copy places and even libraries deliberately mark on the glass with permanent marker to prevent any kind of copy fraud. You can clean the glass with rubbing alcohol or goof off to remove any stubborn ink on the glass and then use some Windex or something, but if its underneath the glass or on the scanner bar you will need to take some stuff apart clean it and place it back. IF you do that make sure its SUPER clean and you dont leave any finger prints on it
Feb 04, 2014 | Sharp AR-M207 All-In-One Laser Printer
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Ihave a hp all in one printer scanner and copier, there is dust under side of glass how do I clean it the model is b110, been like it from new don't seem to be able to get hold off hp
HP says below that for your printer it can't be cleaned except by an authorized dealer. I know from experience that flat bed scanners/all-in-one's have small holes in and around the tray that houses the scanner assembly. If you take canned air and use the long straw that comes with it, you can usually do a fairly decent job cleaning the underside of the glass. It won't necessarily be perfect, but I've found that it's better than what I had before.
You may be able to find several spots to feed the straw through to blow air at the glass.
PLEASE....DO NOT TURN THE CAN UPSIDE DOWN AND SPRAY. You'll inject liquid into the scanner assembly tray and onto the glass. Have someone help you turn the printer upside down or on it's side if you need to get the angle to spray.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=us&lc=en&dlc=en&product=79499&tmp_track_link=ot_search#N89
Flatbed products have a large scanner glass under the top cover.
NOTE:
The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
Regards
Apr 07, 2011 | HP PSC 2210 All-In-One InkJet Printer
Filmy appearance and spots under glass on Epsom V200
Operating heat vaporizes some lubrication grease that condenses on the glass. The glass is removable and can be cleaned like ordinary glass.
Jul 17, 2010 | Epson Perfection V200 Flatbed Scanner
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
Very filmy looking glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 31, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Epson Perfection V200 Flatbed Scanner Logo
607 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
