Question about Dimplex DS5598 Mid-Size Heater
Hearter assembly i need
I need a hearter assembly for the dimplex 22305D1F serial NO.
model NO.6901050100
Its working it is ok now
Posted on Jan 18, 2009
Can i change wattage on my dimplex fire place model dfb 8842
This model does have 2 elements and it will likely cut the wattage in half if you disconnect one. Not sure how hard it is to get to the heater assembly, but there are terminals on the right side that probably have spade disconnects. If so, remove one marked D or E, and tuck it away and see if it puts out less heat.
Dec 19, 2015 | Dimplex Heating & Cooling
Anyone know where I can buy part number 2800090200RP besides Dimplex? it is a small on/ off switch for a electric dimplex small stove model number 6901050100
Some hardware stores, electrical supply stores, radio shack, are a few places I would think of trying. Take old one with you to make sure same amperage/voltage rating.
Sep 15, 2011 | Dimplex Compact Electric Flame Stove...
My heater motor stoped turning and blowing but the heat strip kept heating and melted the rotating fan . It is a 20406D7F 077 can I order a whole complete replacement unit
Yes, you probably can. Plus, Dimplex should be made aware of this. Contact Dimplex Technical Service 888-346-7539, Monday -Friday, 8a -4:30p ET. Have the model number, serial number and proof of purchase, handy when you call.
Hope this helps you get the parts you need.
Apr 26, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I would like to see a Manual for a Dimplex Serial No. 20004D2 183 please.
Would really like to help you, but I need more than the Serial Number of your heater. The Model Number is very important. Thanks
Apr 25, 2011 | Heating & Cooling
I need new light bulbs for my Dimplex Charlotte Optymist fire Model number CRT2OAB where can I get them
The model you have uses a different set of bulbs, than Dimplex's other models. So, you'll need to Contact Dimplex USA, Technical Service Dept @ 888-346-7539. I'm sure they can help you.
Mar 22, 2011 | Heating & Cooling
I need a new flame generator drive motor / spinner for my Dimplex Model No. 6901050100
what kind of on off switch do i need ,has one black wire and one white wire?
Oct 14, 2010 | Dimplex DS5598 Mid-Size Heater
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex DS5598
Disconnect power to unit before attempting to repair unit.
1.With the front door closed,gently place the stove, door side up on a flat surface.
2.Remove the heater assembly retaining screws located on the bottom of the stove with a screwdriver.
3.Lower the heater assembly off of the bottom of the stove being careful not to damage any of the wiring.
4.Disconnect the wiring clips and connections noting their original location.
5.Remove the heater assembly mounting screw and remove the heater assembly.
6.Properly orienate the new heater assembly and connect all of the wiring clips and connections.
7.Reassemble in the reverse order as above.
Pleas note, if you are not comfortable to do this please call your local dealer on Dimplex or go to the Dimplex website and they can locate someone for you.
Apr 06, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex DS5598 Mid-Size Heater Logo
199 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
