Question about Teac USB2 TV TUNER (USB2TVTUNER) Video Capture
Channel gets stuck
When I change the channel on my TV (about 10 years old) the program stays the same. I can tell that the channel is changing, but the TV continues to show the same programing on all channels. If I wiggle where the cable connection going into the TV then the program will change to the appropriate channel. Any advice??? Thanks
  • 432 Answers
I had the same problem on my TY tuner. The connection on the circuit board is bad. Has worked it's way loose. If your good with a soldiering iron you can fix it.
Posted on Jun 22, 2007
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
My tv is stuck on a channel
You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
Dec 15, 2008 | Proscan PS32125 32" TV
Only stays on Channel 2 can't watch DVD's
hello, get a remote from key electronics.
info@key-electronics.co.uk
they will sell a remote to you if they have them in stock , ask about a manual too.
ive spents weeks trying to get help about our tv and wow at last we have some...
christine.....
May 01, 2008 | Disney DTD1363-CAR 13" TV/DVD
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
premtech@willapabay.org
Nov 17, 2007 | Philips Magnavox MS3652S 36" TV
TV channels
Sounds like it lost programing, if it has an "auto program" feature try that, or some older models need it to be done manualy and have a "add/erase" feature, instructions for that should be in your owner's manual.
Oct 31, 2007 | Televison & Video
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Apr 25, 2007 | RCA F32705 32" TV
Teac USB2 TV TUNER (USB2TVTUNER) Video Capture Logo
Top Teac Televison & Video Experts
JOHN TOPLISS
Alun Cox
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
