posted by matty p on Jun 21, 2007
Having a bit of trouble transfering certain track files via usb or cd to a desktop hard drive. The transfered files are saving and opening as wavs, but with no audio information. This is occuring mostly with tracks involving direct ins/outs. Does this happen a lot?
Solution #1
posted on Jan 23, 2008
The initial software for the 2488 had a bug that would not transfer tracks that had punched in audio correctly. The file would transfer with missing audio. This was corrected in a software update. The work around was to rerecord any tracks with punched in audio to a new track then export.
Once this is corrected on a machine normal transfers and exports can be used. WAV files can be exported but have to be copied to the FAT partition on the 2488 then USB to a computer for inport to a DAW.
The FAT partition comes up as a USB drive. Realize that there are several ways to backup and or export your songs,files or tracks depending on your need. IE edit in Protools, move songs to another machine etc.
hope this helps
BB
hope this helps
BB
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 03, 2008
I do this all of the time without a problem. I have noticed when sending files to some of my friends though that they sometimes (depending on what they are using for playback or editing) are unable to open files I've exported as 24 bit wav. You might want to try exporting as 16 bit to see if this works.
Solution #3
posted on Oct 23, 2007
In reading and working with the unit, I have learned that the file transfer is for backup only. If you want to manipulate the file they have to be transferred individually via your sound card or an interface.
Suggest a new solution for this problem
Post a New problem for Tascam 2488 Portastudio Multitrack
Email this problem
Email this problem
Can you Help with these Home Theater Systems problems?
Tascam 2488 Portastudio Multitrack Recorder...
2488
2488
having problem trying to record... Answer This...
problem with the hdd. check the...
i havent used the tascam 2488... Answer This...
bad playback
bad playback
Anytime i record something it... Answer This...
Boot in TASCAM 2488
Boot in TASCAM 2488
Hey.. can you tell me how did... Answer This...
BURNING A CD 2488 MK.1
made a recording 2488 mk.1 and... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
