Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washing machine
We had subzero temperatures and the machine flashed "H" then "F". I finally saw water enter the machine but then it wouldn't spin. There is no water in the cylinder but I can see water in the clear plastic hose underneath the machine. I cleaned the filter out. I ran the diagnostic test and it stopped at C:03 which means there is no hot water getting in. Would that stop it from spinning?
  • kalen22 Jan 17, 2009
    No. It still doesn't work. We have opened up the front of the machine and had a heater blowing for four hours now. Still stops at C:03 when I run the diagnostic test.
    President:
  • 1,990 Answers
Welcome to Fixya! Yes it would. It would cause the Temp Switch to not Engage. Get a Heater in there where it is at and get it warm and then try the Same Cycle again. Let Me know!
Posted on Jan 17, 2009
  • Travis Humphries
    Travis Humphries Jan 17, 2009
    Sounds like you have a Main circuit Board Malfunction.
What is Wrong with my whirlpool front load washing machine,Mod.#GHW9150PW1?
f06 relates to a motor fault....easiest fix is to replace the motor......
cheaper on ebay........cheers
Oct 13, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Error code 5H whirlpool front load washer, what does that mean.
Water temperature sensor control error:
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Jan 11, 2015 | Whirlpool Duet 3.8 cu. ft. Front Load...
Cold water does not enter the Whirlpool Duet front loading washer (Model: GHW9150)
There are two solenoids back where the water enters the machine ( probably an ugly blue color). Possibly the Cold water solenoid failed or the wire feeding the solenoid fell off. Google Washing Machine Solenoid and you can see what it looks like. The Water hoses literally attach to it
Dec 12, 2012 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET WASHER THE WASH LIGHT IS NOT LIGHTING UP WHEN WASHER IS STARTED AND THEN I GET "LF" CODE
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 12, 2012 | Whirlpool WFW9151YW Duet 3.5 cu. ft. Front...
In the middle of a load my washer will stop and starts flashing F23? It is a whirlpool duet steam.
Hi, F23 means that there is a fault in the heating circuit and the heater is not working This fault is triggered if the water fails to rise by 30C or 86F in the first 8 minutes of the heating process.
1. Unplug washer or disconnect power.
2. Check the connections to water heater.
3. Check resistance and continuity of the heating element.
4. Check the water temperature sensor and connections to it.
5. Check the water temperature sensor and connection to it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washing machine, it keep stopping, flashing f h
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lights flashing, F24 flashing washer has stoped
Hi
Thanks for using FixYa. F24 is a water temperature sensor error which is caused when the water temp. sensor value is out of range during the water heating step of the wash cycle. To resolve this issue you’ll have to check the water temperature sensor and its connections. If everything seems to be working fine then you’ll have to replace the water temp.sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water will not heat up why
Check your water supply line (wall) at the hot and cold hose connections to ensure that the hot and cold hoses are installed correctly. Your washer's water temperature is only as good as the temperature entering the appliance. Is water temperature o.k. elsewhere in your home? If not, your water heater may need to be checked for proper operation.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
