Question about John Deere 22 In. Rear Tire Chains
We bought snow chains for our john deere and cannot make them stay on. Cann you tell me where to find a diagram on putting them on? A video even, as long as I can see how to do it. We are getting another 4-6 inches today and would love to use our tractor for removal
  • 3 Answers
Question: How do I install tire chains?
Affected Equipment: All Lawn and Garden Equipment Answer: Getting started:
Safety is always a #1 priority, please follow the steps listed below:
o Work on a level surface
o Ensure your equipment is secure, use blocks if needed
o If possible, install your tire chains in a warm place
  • Removing the tires or wheel assemblies is optional. It can increase the chance of losing parts (such as axle keys and e-clips), but may make it easier to install the chains properly. You can also lift the rear of the tractor to make installation easier.
  • Chains get tangled in the box. Remove the chains from the box and untangle the chains from each other and themselves
  • Lay the chains out on the floor. Take a moment to identify all the parts of the tire chain. Notice that they have a regular hook on one side and a lever fastener on the other side. The regular hook goes on the inside, closest to the transmission. The lever fastener goes on the outside.
  • There is also a "right side up". The opening in the hooks for the cross links always faces away from the rubber tire.
Steps to install:
1. Drape chain over the tire. Make sure the open side of the hooks for the cross links is away from the rubber tire. The regular hook should be on the inside. The lever fastener should be on the outside.
2. Try to center the chain on the tread of the tire as close as possible. Make sure the cross chains are straight across the face of the tire tread.
3. Hook the regular hook on the inside to a link on the other side of the chain. Use the tightest link possible without moving the chain from its centered position on the tread.
4. On the outside of the tire, hook the lever fastener through an open link on the free end of the rim chain. Make sure the extra links do not iwe bought snow chains for - 5tire_chain_outside_hook1.jpg> 5tire_chain_outside_hook1.jpg
5. Next, fold the lever fastener back 180 degrees. If the lever won't fold back all the way, try one link longerwe bought snow chains for - 6tire_chain_outside_hook_2.jpgtry one link shorter.
6tire_chain_outside_we bought snow chains for - 7tire_chain_outside_hook%203.jpgHook the end through a link on the rim chain.<br />
<img src= 8tire_chain_outside_hook_4.jpg 7. Check the chain tension. When the tension is correct, it will be difficult to fit a finger between the tire and any of the chain links. If the chains are not tight, release the lever fastener and move the regular hook on the inside one link shorter, then use install the lever fastener in a position one link shorter. If it is difficult to reach the shorter links, check for cross links that may be caught in the tire treads. Reposition the cross links so they are all as parallel to each other as possible, then try to hook the next shortest links. It may take several tries to get the correct tension on the chains.
8. Reinstall wheel and tire assemblies or let the tractor down, if necessary.
9. Test drive chains by driving the tractor about 40 feet. Recheck chain tension. Tighten if loose. The chains must be snug against the tires. If left too loose, they will fall off during operation.
10. Use wire or a nylon zip tie to secure any excess rim links. This will prevent damage to the tractor fender or transmission case.
Frequently Asked Questions:
Q: Do I really need chains?
A: Probably. Most tractors with turf tires do not have enough traction to operate in slippery conditions. The only exception is Heavy Duty All Tires (HDAP) used on some larger Lawn & Garden tractors which perform well without tire chains on slick surfaces. Tire chains and additional ballast (either wheel weights or frame weights, depending on the model) are necessary for snow removal attachments.
Q: Can I deflate the tires to make chain installation easier?
A: Yes, but it is normally not necessary. Deflating the tires adds another step to the process and only helps marginally. Also, it is easy to accidentally break the seal on the bead of the tire when the tires are deflated, making re-inflation without special equipment difficult.
Q: What is the white powder that's all over my new chains?
A: Some chains are coated with a rust preventative talc to absorb moisture during storage and shipping.
Q: My tire chains fall off when I'm driving. What's wrong?
A: The chains were probably not tight enough. If they went on easily, they weren't really tight. It should take some effort to fasten the lever fastener to the rim chain link. When installed correctly, it will be difficult to slip a finger between the tire and any of the chain links.
Q: Will using tire chains wear the black seal coat on my asphalt drive way?
A: Yes. Asphalt seal coat is a thin coating on the surface of the pavement. Metal tire chains will wear this surface off much faster than rubber tires. If you need more information on compatibility of tire chains and your driveway surface, contact your pavement installer.
Q: Will using tire chains damage brick pavers or concrete driveways?
A: Yes, but the color in most brick pavers goes all the way through the brick, so scratches in the surface caused by tire chains usually don't show very much. Surface scratches in concrete are usually minor and do not show. If you need more information on compatibility of tire chains and your driveway surface, contact your pavement installer.
Q: I have a hill in my yard that I can't get up when I'm mowing because the tires spin. Is it okay to use tire chains to get more traction?
A: No. If you are having any trouble climbing a hill with out tire chains, then the hill is too steep to safely operate your tractor.
Q: My tire chains are rusting. Is there something wrong with them?
A: No, the chains are plated so they will resist rust. However, the plating will scratch off from contact with the pavement. Chains are also frequently exposed to water or salt. These conditions will cause light surface rust. This is normal and it will take many years for the rust to weaken the chains.
Q: Why are the chains so long? The dealer insists he gave me the right chains for my tractor, but they are way too long.
A: Chains are sized according to the tires size that they are intended to fit. Different tire manufacturers and different tire designs will have different tread profiles even though the listed size of the tire is the same. The chains are made to fit all tread designs for a particular tire size. This means that the chains may seem too big or too long for some tires of a particular size and about the right size for other tires of the same size.
Q: Can I install tire chains on the front tires?
A: Generally, tire chains are recommended for use on the rear traction tires only. If you have 2 Wheel Drive, tire chains will not improve traction on the front tires. Tire chains on the front tires of Mechanical Front Wheel Drive (MFWD) or All-Wheel Drive tractors may have interference with steering components which may cause chains to damage the front differential. Changing the tires to Heavy Duty All Purpose tires is a better option for tractors with front wheel drive.
Posted on Dec 11, 2009
  • DonIL Dec 11, 2009
    The images in my previous post did not appear so I am reposting with image files. The instructions can also be found at: https://groundscare.custhelp.com/app/ans...
  • 37 Answers
If you have a small air compressor,let the air out of the tires,put chains on tightly, then refill tires to specs.they will never come off!!
Posted on Jan 18, 2009
How much weight do you need on a John Deer 105 riding tractor with a front snow blower.
snow blower, why do you need any weight? You are not pushing snow you are running up to it and having it blown away.
Having said that, I use Rear chains and 100lbs of weight to PLOW with my Garden tractor
Dec 10, 2017 | Garden
I need a wiring diagram for a John Deere snow blower HM80-155013E
You just go to the link I attached I'm sure you will get the solution of your problem.
Best Manuals
Jun 01, 2017 | John Deere Garden
How can i put a bicycle tire around a standard peg perego tie for better traction
that will give better traction but will shorten the life of the gearboxes. here is a link to a how to video for that very thing. you also could put lines of liquid nails across the treads like snow tire chains pattern. if you get black adhesive it blends in if you dont want it to look ugly. the new hpx tires are expensive but will give much better traction also.
good luck!
http://www.youtube.com/watch?v=AAySJVt6bys
Jan 14, 2011 | Peg Perego John Deere Gator HPX Ride on...
I'm having trouble keeping the chains on my John Deere Tractor. I put them on exactly how the diagram said. They seem pretty tight but they keep falling off when I get out there during snow removal. ...
you need to make shure the chains fit the tire snug and then you need to put a rubber tension band (they usually don't come with the chains) you can get them at a walmart or auto parts store, about $2 for 2 of them and come with little s hooks that you secure to the chain, instructios are on the package, the rubber band you put on the chains on the outside of chains and it keeps tension on the chains so they won't be lose and fall off. hope this helps.
Jan 12, 2011 | John Deere 22 In. Rear Tire Chains
I gave my granddaughter a new peg perego, john deere gator. modle 1G0D0055. i had to push her more than she got to ride. tire traction has had to be a problem in the past with product. why haven't you...
this might help my kids used to play with similar type toys same problem i put some weights on it above the power wheel for more gription hope this works and please vote
Nov 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere 22 In. Rear Tire Chains Logo
787 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
