Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Washing machine
I have an LR code. Is this an easy fix? It is 8 years old.
    Scholar:
  • 79 Answers
Usually, the LR or 'Locked Rotor' indicates a problem with the motor / motor control board or MBC. The MBC is located near the floor on the right side. See www.neptunehelp.com for disassembly photos. The original MCB's had a high failure rate so Maytag redesigned the MCB and the motor. The motor conversion kit is part number 12002039, which includes the new motor, MCB, harness and takes about an hour to install. You can inspect the MCB for either a blown 10 amp fuse or if you see components that are burnt or discolored. If either of these is the case then you will need the motor conversion kit.
In addition, as your Neptune ages you might notice the spin cycle getting louder to where it will sound like a jet plane taking off. If this is the case then you can replace your bearings and seal kit. See www.neptunebearing.com. You can also rent a special Neptune bearing tool called the tony tool which includes the use of a DVD that shows you how to take apart Neptune, replace bearings and install the 12002022 seal kit. I hope this helps...
Posted on Jan 17, 2009
Neptune error code LR, means what?
Maytag & whirlpool was recall Maytag Neptune MAH5500B.
Oct 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washing machine. The error code is Lr. I know what that means, but it is 11 years old and am wondering if it is worth it to fix or just replace.
I would say yes, just remember that replacement washing machines are getting really expensive. First, get a couple of quotes on repairing your Maytag washing machine. Ok, what does Lr. mean?
Maybe I could save you some money, that is if you are mechanical inclinded. GB...stewbison.
Sep 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH5500B error code LR
Motor & motor control board...........machine should have been re-called
Jun 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Lr code
sometime resistor are a bit under valued and can burn up. Dont worry about your door lock. remember Lr stands for locked rotor.????? check the winding on your motor and never over look the pump. Have a visual inside the pump for blockage look for any shorts on your washing machine. I was told they have a ten year warranty on the motor. I always test all the conponents on a w/machine before I test it. lookup this site to see if your maytag is still under warranty???? maytag.com
Aug 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
225 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
