Question about Frigidaire 24 in. FDBB540 Built-in Dishwasher
My dishwasher will not drain. Water is pooled in the washer.
Sometimes the Filter screens in the bottom, can become clogged with food particles. With a few simple houshold tools, you can disassemble it and clean the screens.
Posted on Jan 17, 2009
My G.E. Dishwasher run through its cycles but the water pools and wont drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
May 15, 2011 | Maytag Dishwasher
There is a pool of water in the bottom of the dishwasher...just bought the house, no idea what the problem is....draining issues?
the filter in the bottom of washer iss full of crud.. it pulls out so you can clean it.. do this and get a bottle of dishwasher cleaner and run your washer on a hot cycle with just the cleaner in and it should be fine afterwards
Dec 14, 2009 | GE Dishwashers
Water is pooling in the bottom of our dishwasher. Suggestions?
could be one of 2 problems.
1.drain could be clogged with mineral salt buildup from the water,hair or fiber,etc.remove the drain hose,should be just 2 hose clamps and clean it out.
or
2.if you run a heavy load in the washer they tend not to drain completely.
run the washer empty through a cycle.if it drains then the problem is overload.if it still doesn't drain then the drain is partially clogged.
Nov 26, 2009 | Cell Phones
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
Water pooling at bottom, bad smell, and now doesnt appear to work
My guess is the diverter solenoid which either pumps water to the arms or drains the unit.  It is attached to the waste line on the bottom of the tup.  It can often be disassembled and cleaned.  If not, it must be replaced.
Nov 18, 2008 | Viking 24 in. Professional Series VUD141...
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Not draining
the drain pump is separate from the was motor and is accesed from underneath the dishwasher that help wash moter is one piece and is replaced as a whole unit and the drain hose comes from the factory making a loop up side the tub a lot of installers cut the ties holding the loop to get more drain line if loop is removed will loose its prime and stop draining or drain some times and not others when you first start the dish washers it drains then fills so you should hear the drain pump rum if something isnt jamming it
Dec 30, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Frigidaire 24 in. FDBB540 Built-in Dishwasher Logo
293 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
