Question about Whirlpool GHW9400 Front Load Washer
Duet displaying a fdl code and stops before spin/rinse cycle?
What is the problem? I had a technician come it and he said I would have to replace the whole memory board that is located under the top lid.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    "Fdl" is a door latch failure. Normally this fault is attributed to a defective door latch, but on some occasions the Central Control Unit (CCU), which controls the door latch, can fail and cause the same error code. So...your technician may be right.
    Novelist:
  • 99 Answers
The problem is cold solder joints on the circuit board. When the board was made not enough solder flowed into the larger solder points. The circuit board will need to be removed and the relay and spade connector joints will need to be touched up. If you can make the repair that's great, otherwise take the board and this explanation to a good electronics repair store and they should be able to help you out. Be cautious about OEM replacement boards, they were made on the same line as the board you have now.
Posted on Oct 29, 2010
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loading duet washer stops at the rinse/spin cycle door then locks. code F31 comes up. would this have something to do with the main board?
Hello
Error F31 in your whirlpool duet washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Washing Machines
I have a F11 failure. Initially stopped after 2 minutes. But after disconnecting and reconnecting wires to ccu it worked for a couple of days. Then began to stop after 10-12 minutes - then again F11 fault....
STOP the insanity....that's what you're saying if you encounter the F11 and/or fDL error codes on your washer. If you're not there yet, you will be soon....
The dreaded F11 and/or fDL codes - been there done ALL that!! Our Whirlpool DUET washer is just over 5 years. We experienced our first F11 code 6 months ago (warranty just expired what else is new?). When it first happened, I thought nothing of it - hit the cancel button and the machine reset itself. Then it happened again and again and again. Each time it happened it was more challenging to reset it. I searched for the fix on line - I should have done my research before we purchased the washer.
I was able to determine the error was stemming from the CCU board. Order a new one at over $300.00 and have the same thing happen again - I don't think so. We tried EVERYTHING suggested on multiple websites.....unplugging the washer, hitting the right upper side, checking wires, wiggling the wires, wedging things to improve contacts, soldering, re-soldering, Vaseline, changed relays....anything and everything was a temporary fix. Contact Whirlpool directly? Tried that too, they apparently don't recognize there is an issue with F11 fDL errors, "not a commonly called in concern". Really?? We started searching washers to purchase....I couldn't bare spending $$$ for another washer, but we are a busy active family with 4 kids - what are our options? Then one night after searching the websites for one last desperate attempt at salvaging our washer, I followed through on a link:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
email: selling.surplus@gmail.com
Now, I'm the biggest sceptic in the world and the most frugal consumer - really I am. I am posting my testament to this service because I've been there - frustrated, disappointed, angry. I am so pleased with the service Ed provided - from answering all my questions, to the superb job he did on the CCU. You can review all the comments posted by all his other pleased customers on eBay. I had to stand by my washer for the first 6 loads - just in case the beep beep beeps started. To my astonishment, amazement, and surprise - it never happened!! In my opinion, this is the only true fix for your F11/Fdl error!!
I never imagined in my wildest dreams ever telling anyone how happy I am to be doing my laundry again, but I really am!!
May 10, 2010 | Whirlpool GHW9400 Duet Washer
Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Waher stopped with an sud code and will not do anything. water is in washer.
too much suds in washer--
try using HE detergent-
reset to rinse cycle I think will work-been awhile since I had that code-
ready to throw my GHW 9150 off a cliff-FDL codes-door locks up.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
