Question about Whirlpool LER4634J Electric Dryer
Broken latch on dryer door
The latch on my dryer door does not catch completely, and the door does not close all the way. Heat is leaking out through the door, requiring two cycles to dry one load. Please help
    Champion:
  • 244 Answers
Buy new latch and striker. cheap.
Posted on Jan 17, 2009
  • marty metzger Jan 17, 2009
    buy new latch and striker. should be cheap and easy
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
Door latch won't work
Many dryers have different door latches. not sure what you have.
Check by the latch function and look for broken plastic catches.
Sometimes if you were rough on the door itself, the hinges bend a bit and now the 'Catch ' doesn't align properly
Jun 06, 2015 | Dryers
How do I Close the door on my Bosch WTL 500 dryer
Push it closed.. I guess you mean that the door wont stay closed?? If so, the door latch has probably broken. Either the tongue on the door itself or the latch on the cabinet.
Feb 28, 2015 | Bosch Dryers
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Will not turn on
If I remember correctly, this unit has too door catches, one on the bottom and other on top. When the door is closed, it can only latch at the bottom and not the top, the door switch is at the top only. Try push the top of the door to assure it is closed completely. This should work to solve this issue.
Jul 11, 2011 | Maytag Neptune MDE6700A Electric Dryer
Door latch is broken. Door wont close. Is it possible to buy replacement door?
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Jan 10, 2011 | Bosch Axxis WTL 5400 Dryer
I have ordered a door latch assembly for my cabrio dryer wed6400S. How do I install that latch? Do I take the door apart by unscrewing or just pull that latch out. It is broken and just wiggles. Thanks
open dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
latch assembly:
http://cgi.ebay.com/Dryer-Door-Latch-Catch-279570-fits-Whirlpool-/330503664154?pt=LH_DefaultDomain_0&hash=item4cf38db21a
Dec 02, 2010 | Whirlpool WED6400S Electric Dryer
I have a Kenmore Elite HE4.THe door will not stay shut. It doesn't click anymore when I push the door to close it. Any ideas?
The catch side, not the latch side, the catch on the frame may have backed off some what. It's not unusual for this to happen over time. Take a peek around the catch and see if there are any adjustment options such as two slots where the mounting screws are, a hex key slot behind it to adjust the reach and so on.With a flash light close the door very slowly and from above as best you can see if the spring fed latch is near enough to the catch. Also try hip checking the handle to try closing it.If then it latches you may have a section of seal gasket that is misplaced or swollen. See, not being there makes this a very difficult call. I've given about the most options I can think of and I hope for you guys that one of them works. Also if your closer latch is similar to the operation of a screen door latch, don't be afraid to pry the latch lightly in the direction towards the catch/latch. Good luck and Thank you, Dana
Aug 26, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer door will not stay shut. It seems like the little clip that is supposed to keep it shut no longer catches. Do these clips wear out? It looks fine and seems to fit- just doesn't catch
Take a second look at the door.
Is the spacing the same between the door top and bottom as it fits into the front cover?
Over time, people/children will rest weight on the door as it swings open, bending it downward. You may see rub marks where the door is hitting the bottom jamb.
Pull hard to bend the door back up, OR unscrew and re-tension rhe 4 screws that secure the hinges to the front frame.
The door should close more completely now, Spray a little silicone lube on the latch.
good luck and I hope this solves the problemn.
Aug 13, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
470 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
