Central A/C will not turn on
My central a/c will not turn on. There just seems to be no power to the entire unit. Checked fuse box in house everything okay there. Could this be a bad thermostat? What should I check before calling for service/repair?
  • carolbaran46 Jan 19, 2009
    Thank you very much. I do have a tech scheduled to come out today.
    Scholar:
  • 144 Answers
There is usually a small fuse inside the indoor unit(furnace or air handler). That fuse generally is located on a circuit board and looks like a car fuse. It may be amber or purple in color. This fuse may have blown. If so you may have a bad circuit board. I recommend calling a NATE certified Tech for service as this one has several possibilities. Good luck.
Posted on Jan 17, 2009
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Nutone cv353 unable to stop
You may have a stuck relay or one of your access port switches may be bad. According to the owners manual: "A complete check of all Wall Inlet and Power Unit low voltage control lead connections (external yellow leads). Turn system off by removing fuse or tripping circuit breaker at
house fuse box."
Dec 27, 2011 | Broan-NuTone CV353 Central Vacuum
Have a ford f 350 2004 model manual ****** motor wont turn over replaced clutch safety switch ck starter relays can b pull started
Did you check for power at the starter ignition terminal? It is the small YELLOW/BLACK wire on the starter. If there is power there, replace the starter. If there is no power there, you should check your starter relay an its associated fuses.
The relay primary side is protected by fuse number F2.31 (15 Amp) in the Central Junction Box. This fuse provides power to the clutch safety switch on the WHITE/PINK wire. Then the power leaves the clutch safety switch on the TAN/RED wire and goes to pin 86 on the relay.
The relay secondary side is protected by fuse number F2.113 (30 Amp) in the Central Junction Box. It provides power at pin 30 on the relay, which is also located in the Central Junction Box.
Pin 87 at the relay is the YELLOW/BLACK wire metioned earlier and goes to the starter motor.
Pin 85 at the relay is the primary GROUND. This should be ground at all times.
The ENTIRE starting system can be checked/diagnosed from the pins at the starter relay if you use the correct methods and equipment.
Sep 11, 2011 | 2004 Ford F350
1998 DaihatsuTerios - inaccessible interior fuse box
Take it to your local garage. It took my mechanic 2 minutes to fix a new fuse and cost me 5 quid!!
Jan 20, 2010 | 1992 Daihatsu Rocky
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
Easy Flo Central vacuum will still work at about
Yes you can easily test for a clog, and a crack for that matter.
to test for a clog push a dry garden hose through the entire system until it comes out at the other end.
to test for a crack, Disconnect the pipe that comes from the house to the central vac unit. Turn on the unit and put your hand over the opening directly at the central vac unit.(Using the utility inlet at the unit will not accomplish the same thing.)
  • Step 2 If your suction is good, then reconnect the tubing and turn on the switch at the unit. If there is no switch, plug your central vacuum hose into one of your inlets to start the system. Then have someone completely seal the hose with their hand. While the unit is running go to the exhaust. With everything closed you should feel almost nothing coming from the exhaust. If you feel very little exhaust, then you do not have a leak
  • Jun 06, 2009 | Easy Flo EF2300 Central System Vacuum
    Central Vac will not turn on.
    These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
    Best of Luck
    Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
    Electrical fault
    Malsmed,
    Does your mazda have a central locking unit in the boot? If so then follow the wiring if you can to the fuse block and see where the wiring goes into and check the problem their? If that does not solve the then check the central locking unit in the boot and the ECU unit behind the fuse box.
    Hope this will help you
    Oct 23, 2008 | 1998 Mazda 626
    Central air unit problem
    Check inside that breaker box for fuses.
    Sep 06, 2008 | Amana Heating & Cooling
    Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
    The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
    Jul 06, 2008 | Heating & Cooling
    Heating & Cooling Logo
    185 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
