Question about Microsoft Windows XP Home Edition
Search window opens
Whenever i open any folder in my computer,the search window opens.... how can i solve this problem?
    Scholar:
  • 170 Answers
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
Hi sir can help me for product key of windows xp pro sp3.tnx
HI,
You can find the product key. just follow these steps. Insert Windows XP cd into a working computer. Exit the Auto-run introduction.Open "My Computer" Right Click on the Windows XP cd-rom drive and select explore.Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannotlocate the folder, you may also search forunattend.txtand mark "Search Hidden Files".)Open the sysprep folder. Open unattend.txt Your CD's product key is containedwithin the unattend.txt file.
Jun 06, 2011 | Microsoft Windows XP Professional
Whenever i opens my hard disk D: it opens in a new window
Hi, you can change this setting, open my computer then click on tools and select folder options, in general tab check on browser folder and select "open each folder in the same window" then OK...
if this problem still then it could be virus install latest updated anti virus (avast free, antivir free, avg free) and full scan you computer..
Feb 12, 2011 | Computers & Internet
Lost product key for xp home
The only thing you can really do is purchase a new Product key from Microsoft. I am sure that if you search the internet you could find a product key, but given that it is illegal I wouldn't suggest it.
Feb 08, 2010 | Microsoft Windows XP Home Edition for PC
I have just intalled anti virus and it has messed with my windows activation code so now it dont work and can not find the code
Find Windows XP Product Key from the Windows XP CD: 1) Insert Windows XP cd into a working computer.
2) Exit the Autorun introduction.
3) Open "My Computer"
4) Right Click on the Windows XP cd-rom drive and select explore.
5) Open the USWXP32P_ZX folder.
6) Open the sysprep folder.
7) Open unattend.txt
Your CD's product key is contained within the unattend.txt file.
Note: On some system disks, USWXP32P_ZX is a hidden folder. If you cannot locate the folder, you may also search for unattend.txt and mark "Search Hidden Files".
Oct 26, 2009 | Microsoft Windows XP Professional
I HAVE LOST MY PRODUCT KEY OF WINDOWS XP SERVICE PACK 2
3) Open “My Computer”
5) Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannot locate the folder, you may also search for unattend.txt and mark “Search Hidden Files”.)
Your CD’s product key is contained within the unattend.txt file.
May 05, 2009 | Microsoft Computers & Internet
Regarding slow speed
The setting for opening in the same window is when you are in a folder and you go to Tools/Folder Options. From there, the 2nd setting should be set to Open Each Folder In The Same Window. Next go to the 2nd tab and click Apply To All Folders.
Finally, the increase the overall performance of your drives and system in general, I would suggest running Disk Defragmenter. Actually, I would suggest running it 3 times in a row to make sure your files are fully compacted and defragmented.
You can find instructions on how to run that program HERE.
Mar 10, 2009 | Computers & Internet
I have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
. Open Start >> Run or press Window Key + r , this will open the run prompt.
2. Type “regedit” ( without quotes )and press Enter.
3. Navigate to key
HKEY_CLASSES_ROOT\Directory\shell
4. Double the registry key named Default and set the value to none.
This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
If search opens when you double click on any windows drive, then try this
1. Open Start >> Run or press Window key + r
2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
I hope this will help to fix the trouble.
Jan 17, 2009 | Microsoft Windows XP Home Edition
Folder error
do you have some virus in your sistem.
please download this antivirus nod32 + spybot search and destroy.
Jan 13, 2009 | Computers & Internet
Open drive
select folder view and tick "always use this"
if you double click on your hard drive,it should open in explorer view anyway.
good luck
Terry
Mar 10, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
