Question about Comfort Zone CZ-441 Ceramic Heater
I get lightheaded from the smell/fumes put out by this heater.
I have had this heater for several months (I use it occasionally) and I still am affected by the smell. It resembles fumes of a kerosene heater in it's affect on me. Should I try a non-ceramic heater instead?
  • Anonymous Jan 17, 2009
    yes, it makes me feel a bit sick. lightheaded, nausaus, dizzy-like. not like the flu, though.
    I am now trying a fan-forced heater with a wire heating element. It doesn't seem to have the same smell or effect.
  • Comfort Zone Master
  • 2,888 Answers
If this making you unwell a non ceramic should help , do you get headaches does it feel like you are getting the flu ?
Posted on Jan 17, 2009
New lenomex has a horrible chemical smell - I sprayed waterproof on a jacket and am assume it has picked up fumes. How can I get rid of the smell. it is past its return date and need a fix, please
The heater will burn the fumes off , how long it will take I don't know.,can you put it out side and let it run till the smell goes, never spray any thing on the heater elements you could have a fire.
Jan 05, 2016 | Heating & Cooling
Exhaust fumes comes through my heater in the car
the heater draws air from outside the engine compartment, usually from the grille between the hood and the windshield. check to see if the carpet is wet on the passenger side floor, under the glovebox. I suspect you have a leak in the heater core, and you are getting coolant fumes rather than exhaust fumes. Other signs of a heater core leak would be oily film on the inside of the windshield near the defroster vents, and low coolant level or overheating. If you do actually have a leak in the exhaust manifold, it could be cracked, or leaking from joints in the pipe or where the manifold bolts to the head. If the leak is at the head, you will hear a sharp hiss every time that cylinder fires. You might also be able to feel the hot gas escaping, if you (obviously use extreme caution to not get a severe burn) put your hand near the manifold. If exhaust fumes are getting inside the car, you should also look for unplugged openings in the firewall. The firewall should be as airtight as possible so you should not smell any fumes even if there is a leak.
Feb 06, 2013 | Mastercool ML90062-A-KIT Tecnicians Shop...
Fuel smell inside car when using heater especially on a cold day or when stopping the car
This is a somewhat common problem on Nissan products.
The V6 engine has several small rubber hoses connecting the fuel lines, and when it is cold weather the hoses leak fuel.
The heater - defroster picks up the fumes from the outside vent under the windshield. When you are moving the fumes flow under the van.
If you can find the leak sometimes you can just tighten up a clamp or two.
Feb 06, 2013 | 1996 Mercury Villager
I recently purchased a Holmes HQH319 heater. I want to use it in a room with tropical birds. Birds are very sensitive to chemical fumes. Is there any Teflon or other coatings on this heater that that may...
You would have to contact the makers of the heater to give you a clear answer on that , most heaters smell when first put on from new and you would have to burn this off first ,
Oct 24, 2012 | Holmes Products HQH319-U Compact Heater
Fumes in car
Yeah, and it probably smells like evaporating anti-freeze. Turn off the heater to avoid the smell. Good Luck.
Sep 10, 2009 | 2006 Fiat Pininfarina
Rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Aug 12, 2009 | Heating & Cooling
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Fumes
Generally a kerosene heater will put out a strong smell for a few minutes after it is first lit, and for a few minutes after you put it out. Generally, it will be much stronger after it's extinguished. I usually extinguish mine and immediately set it out on the concrete porch to keep the smell out of the house.
Opening a window for a few minutes right after lighting the heater will help with the fumes at startup.
If your heater is constantly putting off fumes, even after burning for a little while, then it may be time to burn the wick dry. This should be done every few months anyway as general maintenance.
First, siphon all the fuel from the tank. You will need to disassemble the heater and gain access to the top of the wick. Raise the wick to it's highest point and use your fingers or a flat nosed pair of pliers to break up the hard black tar coating on the top of the wick. The smaller you can break the coating, the faster it will burn off. Once thats done, reassemble your heater, raise the wick to it's highest point and light it. It will probably burn for an hour or two because it will first burn all of the fuel soaked up in your wick, but then it will burn off the tar. Finally, it will go out.
After this, you should be ok, to refill your heater and relight as normal.
If you find when you disassemble it that the wick has a hard tar ring down inside, you may have a hard time breaking that up and cleaning it. It is possible... But I would probably just replace the wick.
Nov 21, 2008 | Corona 23-DK Compact Heater
Fumes from Glo-Warm gas heater made by Desa International
If it has not been run for several months it could be dust burning off.
Nov 20, 2008 | Desa International Heating & Cooling
Comfort Zone CZ-441 Ceramic Heater Logo
894 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
