Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson CX5400 won't print on both sides of the sheets
, since I installed it on a new computer that is running Vista Home Premium. Actually it wsd installed automatically when I pluged it in, but when I look to see what printer is installed it tells me that I have a CX5300 installed
  • 119 Answers
You can find the latest drivers and additional info here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=25301&infoType=Overview
Please rate, thks.
Posted on Jan 17, 2009
EPSON L355
EPSON L355 EPSON Drivers and SW
Jan 27, 2014 | Epson Office Equipment & Supplies
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I am attempting to install Epson Perfection 1650scanner to my new computer Acer Aspire. 7735 operating on Vista Home Premium ||Can you help tel. 01621 786793.
Dont you have an installation disc with scanner?If not go Epson uk web site look for downloads or support for your scanner type,download and install
Sep 06, 2009 | Epson Perfection 1670 Flatbed Scanner
Not printing
Epson printers Will NOT print with any empty cartridge installed.(any Colour) replace the empty carts and you should be on your way
Mar 24, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson stylus cx5400 all in one
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Epson America, Inc. - Support: Product Selection - Drivers & Support or Epson Driver Download
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then ifyou get in troubles, followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:someprinterdoes not work on Vista, if you do not find any driver downloadfor Vista on your model page, that means your model is not Vistacompatible.
Jan 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Instsall problem for vista home premium
imexlink:
According to Epson's website there is not a driver available for Vista Home Premium. Please look at the following link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=75683&prodoid=63061037&infoType=Downloads&platform=All
Please let me know what happens. Binary Bob
Nov 28, 2008 | Epson LX-300 Matrix Printer
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Quality Self-adhesive Sheets
Epson Premium Presentation Paper Matte Double-sided
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
244 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
