Question about Water Heaters
No hot water coming out
I have no hot water (no water at all will even vome out when I turn handle to hot) but have plenty of cold...when I ease the handle over to the cold side???
We have gas hot water heater....
  • Anonymous Jan 17, 2009
    same here
  • Thomas F. Schneider May 11, 2010
    No hot water volume at any of the  faucets?
    Valve at water heater turned off?
  • 68 Answers
Check ur pilot light if it doesnt staay lit replace the thurmocuple
Posted on Jan 18, 2009
Excess Hit Water Bill from Solar/electric Hot Water System
10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html
3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Oct 29, 2012 | Water Heaters
Shower goes cold intermittently like there is a restriction in hot water delivery. Plenty of hot water when it comes back, but the cold blast is not fun. No shortage of hot water for long showers or...
Has nothing to do with the expansion tank, the expansion tank whole enough air so that when the heater heats the water it does not build up pressure. You know from school that you can compress ait. you CAN NOT compress water. When you haet water it expands until it turns to steam. So lets rule that out.
First look at all the plumbing in the house where there is a cross conection. This would be like a shower valve that has a personal shower head on it. and you turn of the water using the personal shower handle and not the valve at the wall. This then would let cold water to go into the hot water side piping.
Most people do that with out knowing it at the laundry sink. they put a hose on to was the dog and forget to turn off the faucet and then BANG cold water in the hot side.
Go around the house and turn off all the faucets and valves by using the handles. no add on things.
Now last could be the shower valve itself. . Do this happen in just one shower or all of them???
If its just the one and you spend the day doing the walk around, even check the bidet if you have one
its the valve. you need repair to that.
Best of luck in your hunt Tom
Sep 08, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Takes a long time to get cold water. Then it is still luke warm. New house. Unhook it, and you get plenty of cold water. Takes forever to get hot.
Open water heater drain valve or TP valve to see if unit is producing hot water.
Protect yourself from scalding water.
If water heater is not working, then call service technician, or re-post question on fixya with type of water heater, description of water heater and brand, and what you have done so far to repair problem.
If water heater is working, then you probably have crossover problem at recirculation system check-valve or at single-handle faucet. Or both.
Remove check valve and clean with white vinegar; replace defective single-handle faucet cartridge.
Open following links for resources
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 31, 2011 | Laing Thermotech Autocirc Undersink...
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
I have replaced my electric water heater and I have checked everything I can think of and I still run out of hot water in 3 minutes. What on earth is the problem.
3 minutes?? does the water run cold then? or just warm?
Is this what the tank you replaced was doing? If so, then you may have: 1 a recirculating pump instant hot water system thats faulty and allowing cold water backflow into hot water piping. 2 A tempering valve that has stuck, allowing cold water into your hot water system.
Or maybe a broken or missing dip tube in your new heater.
If after 3 minutes the water is coming cold out leave that faucet running and go to heater and feel the hot water outlet pipe from the heater. if that pipe is hot then the heater is not the problem. If the hot pipe from the heater is cold the heater is the problem. (Make sure the cold pipe coming into the heater is connected to the Right side marked "cold" !) If there is a tempering valve by the heater: feel the output from the tempering valve, if it is cold and the pipe from the heater to the tempering valve is hot, then the tempering valve is the problem. If all these are OK somewhere in your plumbing system hot and cold may be connected possibly a faucet or showerhead that is shut off at the spout/head, but hot/cold handles are left turned on then cold water can backflow thru hot pipe.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Water Heaters Logo
188 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
