Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washing machine
My Whirlpool Duet front load washing machine won't begin the spin cycle. I have tried just "spin" and it won't get to that point. There is no water in the cylinder and it turns, just won't get to spin. Prior to this, it flashed "H" and "F".
  • kalen22 Jan 17, 2009
    I have checked almost everything. Weird thing is - it will run normally with a cold-cold cycle. It won't do anything with hot or warm. When I run the diagnostics, it stops at C:03. So I think I'm narrowing it down. We've had the front open and a heater on it for four hours. Still nothing. Any additional help?
  • 5,911 Answers
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more "involved" error codes that has many possibilities for the cause. I would start with the simple things, first, in an attempt to rule out easy the possibilities. Check your fill hoses to ensure they are not kinked or clogged, followed by verifying your installation to ensure you don't have a siphoning problem, Then, check the drain pump for operation. Read through the link thoroughly andlet me know if you have questions. I hope this helps you.
Posted on Jan 17, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 17, 2009
    C:03 is the segment in diagnostics that tests your HOT water fill portion on the water inlet valve. It sounds like your water inlet valve is bad and requires replacement. That would explain the "low water detect" error code you are getting. I would recommend replacing the fill valve.
    Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Just type in your model number and look uner the "Dispenser" heading. The part number is 8181694.
    The valve can be easily replaced by performing the following checks:
    1. UNPLUG the washer before servicing.
    2. Turn off the water source and disconnect the fill hoses from the back of the washer.
    3. Remove the washer top panel by removing the three screws that hold the top panel in place in the rear. With the three screws removed, the panel will slide back, then off.
    4. The inlet valve is located in the left rear of the washer (as viewed from the front). Disconnect the dispenser hose from the valve and the electric connectors.
    5. Remove the mounting screw(s).
    6. Install new valve in the reverse order of the steps I just provided you.
    Even though you do not normally use a hot water setting, the Central Control Unit (CCU) monitors all sensors within the washer. If a faulty sensor is detected, it will generate an error code. With an error code present, the washer will not operate.
    If you have questions, please let me know. I hope this helps you.
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool sport, won't drain water on spin cycle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't finish the final spin
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Post further comments for more information ....
Good Luck!!
Thanks
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washing machinge is not completing the complete cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Long cycles on my whirlpool duet washer
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
