Question about BenQ FP731 17" LCD Monitor
Unexplained Blank screen.
I run a dual monitor setup for my modelling work, the BENQ FP731 is my secondary monitor, and when i first set it up, it was working perfectly. When i started up my PC today, the of the BENQ was blank. the power is on, the light next to the pwoer button is green, the cables are working and both ports in my gfx card are working, i tested the other connections with my other monitor. the screen isnt exactly blank, i can barely see the BENQ logo when i start it up, it looks as though the brightness was completely turned down but i cant see the menu, or even if its coming up. Is there a way to reset all the settings? or another way to fix this problem?
  • Anonymous Mar 14, 2014
    BENQ G925HDA recently giving trouble. When power applied, the ON/OFF button works but screen goes WHITE ALL WHITE then black. Whenever the PC powers on the screen goes white and stays white...the screen shows n real video at all. Menu button does not work. Un-plugged/plugged-in both leads ( POWER + VGA ) leads no change - still not working like it used to. hs anyone any pointers or even the exact reason? . . . THANK YOU.
Shine a torchligt and if you are seeing the display in the background still then u need to replace a bulb in the foreground of the monitor.
Posted on Jul 28, 2007
3 parts need to replace: 1 of 4 C5705 1 of 2 FU9024 and fuse(black, looks like a inductor)
Posted on Jul 19, 2007
  • BenQ Master
  • 12,061 Answers
Looks like your Power Supply has gone Kaput .. Usually it is the Electrolytic Capacitors on the Power Supply Board, try a new one, or replace ALL the Electros with same or better ones.
Posted on Jul 15, 2007
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
I RECENTLY STARTED USING BENQ MONITOR & NOW I HAVE IRRITATION ON MY EYES. WILL THERE BE ANY RADIATION FROM BENQ MONITORS
There's practically no radiation from LCD monitors, especially compared to older CRT monitors, which radiated several sorts of electromagnetic waves.
Is the picture on your monitor crisp, with good focus? If the letters and shapes are blurry, it may mean that you are using a different screen resolution than the native resolution of your LCD.
If your monitor type is FP731, then it's native resolution is 1280x1024 and this is what should be set in the Display Properties under Settings tab (in Windows). If it's a different model, you can search for it's specs on the web to see what is it's native (a.k.a. optimum) resolution.
Please rate and possibly leave a testimonial if helped.
Jan 06, 2010 | BenQ FP731 17" LCD Monitor
Black out problem
Try a different known working monitor and hook it up to the computer. Turn on the computer and the monitor and see if you can get video. If you get video then you know the original monitor is bad.
If with the known good working monitor you still don't get video then you know its something either with the video card or the motherboard if you have integrated video.
Jun 26, 2009 | BenQ FP731 17" LCD Monitor
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
BENQ FP731
Just leave the monitor for a while about an hour and try connect and see, if not displaying than Try changing the display resolution from your laptop and see what happens.
Oct 16, 2008 | BenQ FP731 17" LCD Monitor
Blank screen
is your Xerox XA7-19i monitor supplied with a fixed DVI-I Single Link cable with Windows Vista?if it has u can connect it via a VGA card which will work with the driver
As a result of this cable configuration recent Nvidia Vista drivers do not detect the monitor causing a blank display and apparent "Hang-up". (Although this is not the case, you simply cannot see what's going on!)
This is a problem that was introduced with the release of new series drivers
May 24, 2008 | BenQ FP731 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Blueish screen
From your monitor menu, check your monitor color temperature. Is it 9500k or 6500k?
Try setting it to 6500K
Dec 31, 2007 | BenQ FP731 17" LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Benq FP731 17" monitor goes Blank after start up
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins
Aug 09, 2007 | BenQ FP731 - 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
430 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
