Question about IBM NetVista PC Desktop
How do u remove the startup passwd on old IBM 350 desktop?
I get three beeps before the request to enter the password. Password was set five years ago and of course I do not remember.
  • ncba Jan 17, 2009
    Is the solution for a laptop? I though the fix for a desktop was to reset the jumbers. if so, how?
  • 837 Answers
Remove the CMOS battery for about 5 minutes
Posted on Jan 17, 2009
  • Jay Glendenning
    Jay Glendenning Jan 17, 2009
    Without the exact model number I cannot give you the jumper location, so I suggested the CMOS battery. There is a jumper .. could you give me the exact model number ?
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
    I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
    Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    Forget passwds
    Take the unit to the location at which you first entered the password. The unit will unlock and you can change the password to something easier to remember.
    Apr 25, 2010 | Garmin Nuvi 350 Car GPS Receiver
    Describe how to retrieve the asus pc password
    Try to remove it with Windows Password Recovery Tool 3.0.
    It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive do this. Booting up and clearing a password takes a minute or two works like a charm. Source(s): http://search.yahoo.com/search;_ylt=A0oG…
    Mar 05, 2010 | ASUS Eee PC 900 PC Notebook
    I forget my Laptop Startup password of IBM T60.
    For IBM/Lenovo Password
    there is solution for all IBM/Lenovo laptop
    check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
    OR
    there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
    check this site http://www.lancos.com/prog.html
    Thanks
    Jan 17, 2010 | IBM Lenovo ThinkPad T60
    How i transfer data from window to linux
    Depending on your linux distrobution, you will need to check the /etc/samba or /etc/smb configuration file, within that file there will be a place to set your windowsfile sharing password. then you will be able to transfer data across the local network between your linux / windows machine again..
    however, if you've actually changed the password for the linux user account that enabled the samba file sharing, you will need to either remember that password, or set a new one from the root account byt typing the following command in a terminal / bash / shell session:
    Task: Set or change user password Type passwd command as follows>
    $ passwd <user>
    Output: Changing password for <user>
    Enter new password:
    Retype new password:
    passwd: password updated successfully
    NOTE: when typing the password, you may not see the password you are typing..
    You need to replace <user> with the username you are changing the password for.
    May 25, 2009 | Dell Dimension 1100 PC Desktop
    Unlock password protected Dell C640
    If it is a passwd set in the bios...good luck. You may have to download a disc from techspot.com
    If it is a windows passwd after the dell splach screen tap F8 this brings up the Advanced Startup Menu. Select safe mode and log in as the administrator. From there you can remove or change the password for all accounts. If there was never an account setup on that laptop and the Administrator account is being used then you will need a disk fron techspot.com to retrieve that password.
    Mar 22, 2009 | Dell Latitude C640 Notebook
    I forgot my user name and passord on my old IBM Thinkpad T20
    try to boot into safe mode and log in as an administrator hold F8 on bootup log into safemode as an admin then go to control panel and change the password for the appropriate account
    Feb 05, 2009 | IBM ThinkPad T20 2647 Notebook
    Resetting iTunes administrator password
    Which Operating system is it ?
    If you have forgotten the admin pwd then you can try the following :
    You need to bootup into single user mode (command+S at startup). It will take you to a command prompt. From the prompt you can do:
    passwd user
    Where user is the shortname for the admin account (you can lookup the shortname from the System Preferences->Accounts pane before you boot into single user mode). You type in the new password twice .. then type:
    reboot
    voila.
    OR you can try...
    At command prompt:
    1.type: mount -uw /
    2. press enter
    3. type: /usr/libexec/register_mach_bootstrap_servers /etc/mach_init.d
    4. press enter
    5. type: netinfod -s local
    6. press enter
    7. type: SystemStarter
    8. press enter
    9. type: passwd root
    10. press enter
    11.type: reboot
    12. press enter
    Dont forget to rate this!
    Dec 01, 2008 | Apple iPod classic MP3 Player
    Startup Password IBM Thinkpad T40
    How to Reset an IBM ThinkPad Power On Password Using Hardware If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware. If only the power-on password is set, do the following to remove the power-on password. Power off the computer Remove the DIMM cover on the bottom side of the computer. Short-circuit the two password pads or put a jumper on the contacts to short the circuit. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed. Reinstall the DIMM cover. If both the power-on password and the supervisor password are set, do the following to remove the passwords: Power on the computer by pressing and holding F1. Enter the supervisor password. The Easy-Setup menu appears. Click on the Password icon. Click on the Power on icon. Enter the supervisor password and press the Space bar. Press Enter twice. Click on Exit; then click on Restart.
    Aug 25, 2007 | IBM ThinkPad T40 2373 Notebook
    IBM NetVista PC Desktop Logo
    46 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
