Question about Bosch Classixx WFL 2066 Front Load Washer
How to clean the filter?
How do you remove the cap to clean the filter?
  • Bosch Master
  • 3,463 Answers
Assuming you have located the filter at the front bottom of washer, unscrew it anti clockwise, and pull it out to clean.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
My Bissell P:rolneat will not dispense water through the floor unit or the wand.
Check the filters. Flow Indicator: Turn Indicator cap counter-clockwise, remove rotor, next remove filter. Clean the filter and replace items in reverse order. Additionally, now is a good time to clean the Lint Filter on the tank cap. These filters are recommended to be cleaned after each use. Hope that helps, if not Bissell Consumer Care can be reached at 1-800-237-7691.
Nov 28, 2015 | Bissell Vacuums
Bissel carpet cleaner not sucking up dirty water why ?
Sounds like a clogged filter. Try cleaning the Flow Indicator Filter (turn Flow Indicator cap counter-clockwise to remove it, lift out rotor and filter under it. Clean filter and reinstall in reverse order); Check and Lint filter on the Heater tank Cap. All filters are recommended to be cleaned after each use. Bissell Consumer Care number is 1-800-237-7691
Nov 24, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
What's causing it to pour out to much solution
Solution distribution problems are usually the filters. If you haven't been cleaning them after each use than now may be the time to clean them. There's one on the Water Tank Cap on the inside (looks like a screen) just remove it, clean and replace. The other is Under the Flow Indicator. Turn the Indicator cap and remove, lift rotor out the filter is under it, remove filter clean and reinstall in reverse order.
Apr 24, 2015 | Bissell ReadyClean PowerBrush Deep Cleaner
I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Lint will not come off clothes when washed in my older whirlpool front load washer
Clean the pump filter screen.... Remove bottom front panel see filter housing located next to pump unscrew cap by turning counter clockwise... Clean/remove debris located inside(place shallow pan under housing and remove cap slowly so you can reinstall if pan get full)... Be prepared for some water to leak out when cap is removed(could be up to several gallons depending on how clogged up it is) .
Nov 03, 2010 | Whirlpool Washing Machines
I need "step by step" instructions on how to replace the fuel filter on my 2001 Dodge Ram 3500 pickup. Thanks !
Here you go if it is a diesel:
A. FUEL FILTER REPLACEMENT:
The fuel filter is located inside of the fuel filter housing
1. Unscrew and remove fuel filter cap at top of fuel filter housing. To unscrew, attach tool to 6-sided hex center of cap. Do not loosen cap at outer edge. The fuel filter cap is designed to remove filter while pulling up on cap.
2. Remove O-ring from cap and discard.
3. The filter is retained to cap with little fingers. Carefully pry a couple of them off from old filter.
B. FUEL FILTER REPLACEMENT:
1. Thoroughly clean inside of filter housing, cap, etc. with clean diesel fuel
2. Fill filter housing (canister) with clean diesel fuel. NOTE: If you do not do this, you will have to manually bleed air out of system later. No fun.
3. Snap new fuel filter to bottom of cap.
4. Install new O-ring
5. Apply lihgt film of clean diesel oil to cap O-ring
6. Load filter/cap into housing.
7. Tighten cap to 25 ft. lbs. torque. Do NOT over-tighten.
Sep 03, 2010 | 2001 Dodge Ram 3500 Truck
Change the oil
1.prepare materials needed such as:
  • An allen wrench or screwdriver (for fairing removal, if necessary.)
  • An oil filter wrench (for removing the oil filter.)
  • The appropriate crush washer for your oil drain plug-- this can be purchased from a hardware store or motorcycle service shop.
  • A pair of needle-nose pliers, in case the oil filler cap is hard to reach or tightly screwed on.
  • An adjustable socket wrench.
  • Clean rags.
  • The proper amount of manufacturer-recommended engine oil.
  • A new, manufacturer-approved oil filter.
  • A funnel
2. Unscrew the oil filter caps 3. Remove the oil rain plug 4. Replace and remove the crush washer 5. Clean the oil drain plug 6. Remove the oil filter 7. remove and clean plastic mesh filter 8. Lubricate the O-ring of the new filter and attach it to the engine 9. Replace Oil drain plug and plastic mesh filter then pour oil 10. Check oil level
Jun 14, 2010 | 1983 Honda XL 125 R
Kenmore Quiet3 not cleaning top rack, now stopped cleaning all
The problem is likely that the cutter/chopper filter is plugged. This reduces or eliminates water flow to the cleaning arms.
Solution:
Remove dish baskets
Remove bottom arm - Rotate the centre post until arm is free to be lifted out.
Remove conduit to top arm(s) - Remove 2 screws, one at top and one at back. Rotate whole conduit 45 deg right and lift off of centre post.
Remove bottom plastic assembly. - Remove 4 screws and lift off.
Remove cutter cap. - Remove 1 screw at front left. Lift off plastic cap. Remove cutter filter. It is on a spring loaded pin. Pull cutter blade foreword and lift filter disc straight up. Clean filter disc thoroughly
Reassemble!
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
My kenmore dishwasher isn't cleaning the dishes very good
Your broblem is probably the cutter/chopper filter. This is located under the bottom cleaning arm assembly.
Remove the baskets.
Remove the bottom washing arm. Unscrew the centre post and lift off the arm
Remove the conduit to the top arm(s). Remove screw at top and at back. Rotate the conduit assembly 45 deg right and lift off.
Remove 4 screws (Star T-20 bit) and lift whole assembly out. Pop off screen and clean.
Remove cap over cutter/chopper. There is one screw at left front under assembly just removed. Remove it and the plastic cap (Needs some wiggling to free it up). Remove the cutter and filter. It is on a spring loaded pin. Pull in foreward and also lift the filter disc up and out. Thoroughly clean the filter.
Reassemble
Dec 01, 2008 | Dishwashers
Bosch Classixx WFL 2066 Front Load Washer Logo
262 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
