Question about Intel Motherboard
Mother power some time power on & some time power off my solution is powrsapply problem pentiam-1
    Genius:
  • 1,913 Answers
Change your smps.
Posted on Jan 17, 2009
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Device 22 toshiba fax
okay. Solution pertains to device errrors 22 thru 25.
step 1: Is the cable from the fuser firmly connected to the Low Voltage Power Supply at (CN3), between the mother PBA (Cn24) and the Main PBA (Cn12)?
step 2: Is cable from fuser firmly connected to the mother PBA (CN4) between mother PBA (CN25) and the Main PBA (CN13)
step 3: if connections seem good and problem error code persists, replace in this order:
1. Fuser (call 888)690-7283 to order.
2. Low Voltage Power Supply
3. Main PBA
4. Mother PBA.
Oct 20, 2011 | Toshiba DP120F All-In-One Laser Printer
When i press power switch, mother boards power became off.
mother board problem.. u have to change ur mother board or u can do 1 thing just open the restart connection.form the mother board.
Mar 29, 2011 | Intel D845GVSR Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Jan 27, 2011 | ASUS K8V-MX Motherboard
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
The laptop wont power on. the power supply has a quick flashing when plugged into the laptop but no flashing when not plugged in.
hi , it might be the mother baord power conector over time the burn out . lets do some test. 1, try another power supply of a same model and watts. 2, take out the battery try new power supply . if this doesnt work then chances are the power circuit board has failed might have too replace mother baord thanks hope been some help.
Sep 25, 2010 | Acer Aspire 5920-6727 Notebook
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
I lost my sound driver for intel pentiam 4 mother board 101gctl
Go to the following link, and select your operating system from the drop down box, and it will take you to the drivers you require.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2229&lang=eng
Jun 12, 2009 | Intel Computers & Internet
Cant Open My Pc Even Though the power supply is OK
had this problem the other day, when i was running my pc... When I turned it on,,, the lights on the switch on blinked and my pc runned for only 1 second then i started reconnecting things like the MEMORY CARd the proccerssor the power cables everthing and when i tried it again,, it worked but then suddenly my monitor's light behind its switch are blinking and i turned my cpu on and off then... after the fifth time i am turning my pc.. it does not turn on. My power supply is working because i tested it on the other computer.. I cant Figure out my problem so please help me..
May 23, 2009 | Computers & Internet
Computer not powering on
There are various reasons a computer may not power on ....... there may b a problem with the power supply , there cud b a problem with the mother board .....
Try
open the cabinet ...... remove the main power cord connected to the mother board wait for a few seconds and connect back ...check
Oct 18, 2008 | Sony Ericsson K800i Cellular Phone
Intel Motherboard Logo
14 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
