Question about Adapters.com Serial ATA IDE Converter and IDE to SATA Converter (SSIDEDD1)
Device drivers market as corrupt
The device ARQJ4OH IDE Controller,is reporting "tv_ConfigMgrErr39"
I would like to know the solution for this problem.
The plug and play ID for this device is ACPI\PNPA000\4-5D18F2DF-0
I use windows vista basic.
Thank you
  • 24 Answers
Try to delete the item with the yellow ! in the device manager and reboot the system.
Once the system restarts it should look for a driver usually and ask for the disk. It might tell you then what hardware it is and you can look for the proper drivers.
Posted on Jan 19, 2009
Toshiba sd-r2312 driver corrupted . how can i update it ?
There is no such thing as a specific driver for cd/dvd readers/burners.
The operating system itself has suitable drivers for those devices.
However, it can be that the driver for the IDE/ATAPI-controllers is malfunctioning.
If you have chipset drivers for the mainboard, reinstall them. Otherwise remove in
the Device Manager the driver of the used IDE/ATAPI-controller and let the Device
Manager search for the Microsoft Windows drivers and install them.
Jun 12, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Hello, I have a Toshiba laptop. Under device manager; storage controllers; AYKXP31L IDE Controller; ''Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code...
hi basically what it is telling you is that it does not support that controller with the software supplied, the only thing i can suggest is to go onto microsoft windows 7 site and obtain a driver for that particular controller or visit the toshiba website and see if they have an updated device driver for it but that's all you can do ime afraid...hope this sorta helps
Feb 23, 2010 | Computers & Internet
Problem using VT6421 card as extra IDE port. I
First, you have to know if all driver components is installed in your computer, I'm talking about your motherboard make sure that all the drivers is installed.
View the status of your device driver.
If you are using Windows base Operating system like Windows XP open this menu:
Start Menu > Control Panel > System icon > go to Hardware tab > click Device Manager
Look for the question mark, it indicates a not working device.
VT6421 is a Serial Raid Controller
http://www.via.com.tw/en/products/peripherals/serial-ata_raid/vt6421/
Refer to the product specification of your motherboard, view this site:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2314
Download and install the Device driver for The Raid Controller of your Motherboard
Jan 13, 2010 | Intel Motherboard
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
Both Drivers for CD Roms wont work for Dell Dem 2400
The two devices are both hooked to your secondary IDE channel. It could be that the IDE controller driver is corrupt or missing. Go to the Dell website, download and reinstall the CHIPSET driver, which includes the IDE channels. Then reboot. The driver page is here:)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Failing that, verify that the drives are visible in the BIOS setup. When you restart and see the Dell splash screen, press F2 to go into the BIOS setup, come down to Drive Info and see if the model is reported for the two opticals. Perhaps it got disabled there, but not likely unless you were changing settings.
Another possibility is whether you removed and CD/DVD recording software recently (Sonic, Roxio, Nero) as these may have changed the registry entries related to your CD/DVD drives.
If nothing works, please post the specific error code reported by the Device Manager. Right click on each drive in the Device Manager and it should be listed in the device status box.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Computers & Internet Logo
999 people viewed this question
Top Adapters.com Computers & Internet Experts
JP Services
JP Services
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
