Question about Dell E173FP 17" LCD Flat Panel Monitor
Horizontal banding on Dell monitor
I have a 19" Dell Flat Panel monitor that has recently developped horizontal gray bands across the display. The bands extend from all the way across the display, some are wider than others with the widest one being about 1/2 a centimetre. This problem seemed to develop after the monitor had been turned off for about a week but that fact could deffinitely be unrelated to the problem. The bands are only visible on white backgrounds - my wallpaper, for example, is darker colours and I cannot see the bands there.
    Problem Solver:
  • 19 Answers
Hello, My name is Richard and I am part of Dell's Online Community Outreach group. Looking at you monitors issue; it would be most advantageous that you contact our technical support. Your monitor seems to be a fairly now model and is probably still under warranty. Call 1-800-WWW-DELL and provided the technician the PPID number on the back of the monitor. The Dell rep will be able to determine your warranty options. Regards, Richard B Online Community Outreach
Posted on Jun 26, 2007
SOURCE:
Displays horizontal black lines
It looks like you may have a screen fault which will need replacing
Mar 09, 2015 | Televison & Video
Dark band lcd tv
Back-light fault. Contact any service technician. The panel might be taken out for repair. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have horizontal red pixel bands going across the screen and the unit is less than three years old.
One of the component in the horizontal section of your flat tv, is bad. Required repair y service technician.
Jul 27, 2009 | Televison & Video
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Jan 18, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Lines across screen
Is it sort of rolling almost.
If so you have a few bad capacitors in the power supply that need to be replaced.
If you dare to venture inside you should see 1 or more buldging caps. (bowing upwards on the top)
If these start to fail, then they will interupt the correct flow of power and cause this problem with your panel.
Easy to fix if you are electronically minded, if not, take it to your local TV tech and it shouln't cost that much to have repaired.
Remember, inside these monitors is high voltage that can kill, even if it's not plugged in.
Dec 10, 2006 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Dell E173FP 17" LCD Flat Panel Monitor Logo
359 people viewed this question
Ekse
Clive
Clive
