This model Maytag is actually manufactured by Whirlpool. To access the lid
switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in
towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid
switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
