How hard is it to install the basic honeywell thermostat non digital I believe #YCT87N1006. I just want the basic stuff no digital that keeps shutting off my furnace
  • 2,559 Answers
Here are some instructions.
Please rate this solution
Posted on Jan 17, 2009
Purchased a honeywell thermostat. RTH111B1016A thermostat
It should have been included with the unit. If not try this link:
Nov 16, 2014 | Honeywell home rth111b1016a digital non...
Programmable Honeywell
A Programmable Honeywell Thermostat is a great investment for you to make for your heating and cooling system. A Honeywell Thermostat will provide you with the best in comfort and dependability for many years.
Many people when they think of Honeywell Thermostats think of the old round T87 thermostat that has been one of the most common thermostats for years and years.
Today they have those thermostats in designer colors and they are still made and used in many situations. But the manual thermostat is quickly becoming a thing of the past. With the rising costs of fuel the Programmable Honeywell Thermostat is becoming more and more popular. Programmable Thermostat Honeywell is even one of the most popular searches when it comes to thermostats.
The VisionPro thermostat line has quickly become one of the leading digital programmable thermostats on the market to today. The ease of programming this thermostat and the touch screen interface has made it a very popular choice for many people. There is a variation of this thermostat for virtually any possibility that you can think of. The FocusPro line also is a very good choice at a bit less cost. There is a basic Pro line and also even a digital thermostat in the traditional round configuration. Both digital programmable and basic digital thermostats are available for line voltage control of electric heating.
Along with the thermostats you now are able to add remote outdoor sensors as well as install you thermostat in a remote place and run a sensor to the space you are controlling. For many years these capabilities were standard for commercial thermostats, but now they are a very real possibility for home use also. With an outdoor sensor these thermostats now have the capability to turn off your heat pump and start you backup heat a certain preset out door temperature. In the past many systems have been installed with complicated electronic to do what a thermostat can do very easily.
The Programmable Honeywell Thermostat has come a long ways in the past few years. The changes have made this thermostat capable of doing many unbelievable things. If you are looking to replace your old thermostat, carefully compare the many thermostats on the market and then pick the one that will meet your needs the best. For many the Honeywell digital thermostat will be the best choice, giving them great flexibility and reliability in one thermostat.
on Jan 15, 2010 | Heating & Cooling
I have a honeywell thermostat, It keeps blowing even when I try to turn it off. Could you please tell me what is wrong with it? And can I fix it myself?
Do the easy stuff first! Is this a new install or has it been working well for a time and now it is not? Is the entire unit continuing to run or just the fan? Thermostats generally turn the unit on and off when the desired temp is reached but the fan itself (not the compressor or heat strips) typically operates in 3 modes, off, on or auto. check the fan setting.
Nov 15, 2014 | Honeywell TH5110D1022 Focus PRO 5000...
Honeywell com yourhome
Yes, it should work. Old thermo has 4 wires, follow instruction with new thermo.
Jul 22, 2014 | Honeywell Universal Digital...
Honeywell TH5110D1006 FocusPRO NonProgrammable Thermostat Is there any trick that can make it so I can keep a child from messing with the thermostat Anything even if its just disabling to buttons We leave...
I believe you can set a range stop in installer mode, the instructions are here but if you have difficulty ask your installer as if you don't know what you are doing you could stop your system working by changing the wrong settings in installer mode.
Apr 02, 2014 | Heating & Cooling
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
Installed my thermostat and the heat keeps climbing where did i go wrong? it is a honeywell Honeywell RTH221B Basic Programmable Thermostat
Make sure red wire is on R terminal, white wire is on W terminal. Also look for a short in the thermostat wire.
Oct 17, 2009 | Honeywell Electronic Programmable...
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
