Question about Creative Labs WebCam Live!
Copy music or data
When i put a music disc in the writer it regonise it and copy to its harddrive but if i put aclean disc in the writer it writes back on the blank disc but!! the disc dont want to play and you can see that its been written
How to copy dvd to laptop harddrive
Is the DVD formatted for music or data ??
If it's data, you'd click the Computer Icon on your Windows software and move the files from your DVD to a directory a hard drive like any other.
If it's formatted for music, you'd have to use something like Windows Media Player to "Rip" songs from the DVD to the Media Directory...
Feb 16, 2014 | Computers & Internet
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
My dvd not writing but read
There can be several reasons for that. Try to use Nero software if you are using LG SUITE. Also the DVD write speed and format has to match that of your writer. Ate you copying another DVD or writing data or edited media such as movie video or music files? Check compliance format.
Jul 11, 2013 | LG SecurDisc 20x Internal Double-Layer DVD...
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
The DVD/CD writer on my Acer laptop is not correctly writing discs. It is writing music files to the disc but it does not play on CD players - it is like the music is on it is as data files as when the...
When you want to create an audio cd, you select audio or mp3 in case you CD player also play mp3. Do not copy or write music file to your cd as data files.
Dec 22, 2008 | Computers & Internet
Dvd cd writer does not detect disc in drive when i want to burn
Sometimes you need to have a burning software like nero or roxio, if you want to get music from an audio cd you can use rip by going to the windows media player but if not tell me what kind of software you are using for copying.
Oct 19, 2008 | Dell Inspiron 6000 Notebook
Downloading and burning on a compaq presario 2100
If u want Burn the Music CD just select the option copy disc option and it will copy all data to memory then it will automatically ejects and ask for a blank disc just remove the music disc and insert it with a blank disc it will start writing i.e, burning then finally it will come out and u r music disc is ready
U have lot of software to burn a disc most commonly used is
NERO
Windows default Windows Media Player
ROXIO
If u Have any doubt or a clarification please describe the problem Clearly
Oct 06, 2008 | Compaq Presario M2000 Notebook
LG DVD writer problem
You should be using the software "NERO" to burn discs.Goto>start>all program>Nero>Data>NeroExpress
Here you clearly see the two types to burn disc "data cd" and "Data dvd".
Need More help?.if yu are using another software whats that?
Mar 07, 2008 | Computers & Internet
Dvd re-writer will not read any blank discs
if you have nothing on the cd then it won't read it cause there is nothing for it to read... so if you have a writing software that you can write the cd you can write the cd... only if there is something on the cd it will read......
Mar 05, 2008 | Computers & Internet
Copying data on to a DVD
What type of application are you using? I know that the new nero requires you to choose whether you want to write to dvd or cd before it will work. maybe your application is similar.
Aug 01, 2006 | HP CD-Writer 9900ci CD-RW/DVD-ROM Burner
Creative Labs WebCam Live! Logo
13 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
