Question about Sony KP-57WS500 57" Rear Projection Television
The 3 colors are off, i have shadows and arches in the screen
Can anyone tell me what is wrong and/or how to fix this problem. The picture arched up in the middle from the bottom and arches down in the middle at the top. There are shadows on the screen, and the colors are messed up, for example, when there was a picture with a pole, I saw three different poles, one blue, one green and one red.
I took the front cover off and tried my best to tune the knobs.
Any help would be greatly appreciated.
  • mweb218 Jan 17, 2009
    Would the D board be located inside the front, behind the speaker grille? I think replacing the ICs would be easier and less expensive than replacing the cartridges. So how do i find out what the STK number would be? Do I look at the ones currently in the TV set?
  • ridgid65 Feb 19, 2009
    I had this same problem. I followed welcomegee advice and it fixed the problem! Thank You !!!
  • 81 Answers
Search in TV .you have a
cartridge of the colores red yellow and bleu. that
cartridge damaged change it buy other new
Posted on Jan 17, 2009
  • 10,594 Answers
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
  • Shahid Electronics
    Shahid Electronics Jan 17, 2009
    You TV requires STK392-560 quantity 02 replacement.
    Above part is available in Part Store and you can see part image by clicking Part Store.
    You can have access to D board by taking off of rear / back cover of TV as D board is located inside TV.
I Have a major convergence problem. It is a 55 inch Toshiba ColorStream Projection TV(tp55h95). It was fine until we moved it into the other room, and now it's like the color is bending at both sides of...
Color arching.... Ahhh Yeah they eventually do that after a few years. Good news is all you need is a screw driver and some of your time and patience.
The color gun is a small box with 3 screws on it. (Blue, Red and Green. Turning the screws (Slightly) on the gun will get rid of the color arching. I had blue arching on a sony 65" Rear projection a year later it was red arching if you leave it long enough it will be arching and in and out flashing of solid color. Whole mind trip you don't want to venture on.......
The box on my sony was in the very front of the tv. I removed the front speaker panels and accessed it very easily. The hardest part is getting the front panel off. Yours may be in the back.
Best regards and Semper Fi...
Aug 06, 2010 | Toshiba TP55H95 55" Rear Projection...
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture Falling with arch
It is your convergence IC's going out, they cost about 40 $ for both, if you know someone that can solder, i would have them do it, once you see the new parts it is prity easy to find them on the board in your tv, repair shops usually charge 4 to 5 hundred
Jan 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen shadowing with colored lines
This is most likely a convergence problemand can easily be fixed. If you can solder you can repair this yourself. First try resoldering the pins on the convergence ICs. If that failes to resolve the problem, replace the ICs. THese are large black Ics attached to a heatsink and may be marked STKxxx.
Keep us posted.
Dan
Jun 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
need to replace both convergence ICs numbers STK392-560 you can get replacements with free instalation instructions with pics so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Apr 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
