My computer`s performance is very very slow what could be the problem
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 6 Answers
Just go to run (windows+r ) type %temp% . try deleting some of the temporary files. or to increase the performance of your computer.... right click on my computer icon in your desktop->properties-->advanced tab--> performance-settings--> advanced tab--> virtual memory-change--> set the custom size of initial size as 3000 and max size as 3500, press set--> ok--> ok-->ok, once u have done this restart your computer.
Posted on Jan 17, 2009
Why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
Tip
Fix a Sluggish Computer
The<b> computers</b> work fine when they are new. But over time the increase in use, it reduces the overall performance of your <b>computer</b>. I wonder what could be the cause of poor computer performance. Well, there are several reasons why your <b>computer </b>may slow down. Applications may be a virus, or it may be a register has been damaged. Go through this article and find out how the speed of computers can be added.<br /> <br /> There are some common reasons why computers can slow down. Over time, junk stored on your computer, which ultimately reduces the performance of your<b> PC</b>. If these reactions are smoothly removed at a periodic interval, they will never come across problems like speed to the computer. To make your computer running at its best, you can hear a provider of computer support services remotely. Many companies offer <b>computer repair</b> technical support for <b>PC users</b> at a price easily.<br /> <br /> You can also perform some simple tasks on their own in this regard. If done correctly, you can not face problems like a<b> PC slowdown</b>. You must first clean junk application. Windows stores large amounts of data where a substantial part is useless and corrupt. You need to get rid of computer waste in order to increase computer performance. Whether you have a <b>laptop</b> or <b>desktop computer</b>, perform this task on a regular basis.<br /> <br /> Take care of your Windows registry is also another important part of fixing slow computer problem. The registry is a very important part of the Windows operating system because it contains information on all personal computer software programs. Corruption in the Windows registry can cause errors and crashes. For faster <b>performance computer</b>, you must delete the invalid registry periodically. You can find many registry cleaner software on the market. Choose one of these programs and clean your registry. <b>Cleaning</b> the <b>Windows registry</b> can also be performed manually. But most users do not have sufficient expertise and talent to accomplish this task.<br /> <br /> <b>Defragmenting </b>a<b> hard disk</b> is one of the most important ways to improve computer performance significantly.<b> Disk Defragmenter</b> has a utility for the <b>Windows operating system</b> and you can easily use. Select the disk and defrag is faster.
on Feb 03, 2011 | Computers & Internet
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Macbook pro desktop folders slow to open
There are quite a lot of causes for a running slow or lack speed MacBook computer, if you prefer a quicker yet easier way to fix the performance issues, see: http://www.speedupmacbook.com/
May 10, 2012 | Computers & Internet
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
Tip
Fix Slow Computers
Computers are used to make our tasks easier and perform them in shortspan of time. However, if your computer starts working slow, then thereis no major significance of having it and using it to carry out varioustasks. Many people get frustrated with the slow performance of their PCand end up spending money by upgrading memory or even sometimes bypurchasing a new computer to get rid of slow performance. However, youcannot do it every time your PC becomes slow. You should look for amore efficient solution.
There are numerous ways to fix your slow computer without having to spend money or to carry your PC anywhere.
Computers can become slow due to several reasons. Given below are some of the possible reasons:
1. Low disk space available on the hard disk
2. Presence of excess temporary files
3. Corrupt registry entries
4. Large number of software applications installed on the computer
5. Presence of incompatible device driver in the system
6. Excess heating of computer
7. Corrupt data
8. Corrupt operating system
9. Presence of virus and other malicious software
There are various other problems which may slow down your computersystem. Now, let us highlight some important steps to fix the issues ofslow computer performance with Windows operating system. Note: Take abackup of your complete data before carrying out any steps.
1. Remove all the temporary files stored in your computer system. Thetemporary files are voracious eaters of system memory. So, the bestpractice to improve the system performance is to regularly delete thetemporary files from the computer.
2. Regain the hard disk space by launching the Disk clean up utilityprovided in the Windows operating system. If even after cleaning up thehard disk from unnecessary programs and files, the space available onthe hard disk is less, then you can uninstall old programs which arenot in use.
3. Update Windows by turning on the automatic update feature when connected to Internet.
4. Registry is a central database of any computer which maintains arecord of the activities and stores them in the form of registryentries like when you install any software application on your PC thenan entry is made in the registry about the installation of thesoftware. So, check for any registry error.
5. Install a good security suite like antivirus and antispywaresoftware and scan your system for the presence of any suspiciousprogram code installed on your computer and eating up your computermemory and remove it to make your system fast.
A computer is a machine which requires regular maintenance for showingbetter performance. Regular maintenance is the best way to improve theperformance of a slow computer.
on Feb 03, 2010 | Computers & Internet
Asus k52j is working very slowly
A slow computer could becaused by a number of things -Please click on this link and follow my instruction to speed up your computer :-
http://www.fixya.com/support/r5946321-fixing_slow_laptop_desktop_computer
Apr 26, 2011 | Computers & Internet
My pc.. desktop is very slow.. its a windows vista
You may want to look into upgrading your RAM if there is less than 2GB installed. This is a recommendation that I have found in working with several PC's running this Operating System. Also, you would want to run disk clean up and remove any temporary files that Windows finds. Deleting any other temporary or unused files from your PC on a regular basis should increase system performance. In addition, if these steps do not solve your problem, you may want to consider upgrading to a faster performance hard drive (preferably a SATA II with a 32MB cache). As a last resort, you may look at your CPU to see if there is an upgrade for it, as well. Keep in mind that Vista is a resource hog and can slow down a PC within just a short period of time.
Oct 15, 2010 | Computers & Internet
Slow computer, seems to hang alot. how do I speed it up. done all the usual things.
the problem is u have a lot stored on the pc memory and when this are much it slow down your computer so what u need to do is check your desktop and delet some things u no longer needs or dont open too much pages on your home page this can make your pc slow down ok,thnks .
Jul 10, 2010 | Compaq Presario Notebook
When it is powered on it goes in super duper slow motion to open windows and then to load everything almost not starting or loading . it takes hours to get to have computer loaded.
Check out the tips and tricks on this site. Several of us have written tips concerning how to speed up your computer.
The tip I wrote is:
Why is my computer so slow and how do I fix it?
Jan 14, 2010 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
