Question about Ricoh Aficio 1018D Copier
Functional Problem on our Ricoh 1018D
The panel reads SC 544 and says to turn off and back on which I have of course done a few times. The machine does not boot up.
    Sniper:
  • 86 Answers
Enter SP mode - Clear (yellow) key, 1 0 7 and hold and press stop (orange) key for 3 seconds.
Enter SP 5-810 (SC code reset) and
select “1”. Then switch off and on the machine.
If error still there, probably you have one of the following faulty;
Fusing thermostat open,
Fusing thermistor open or defective,
Fusing lamp open or
Power supply board defective.
Please, first check fusing lamp and thermostat for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Help need for getting rid of SC 544-00 on a Ricoh SP C830DN machine.
SC 544 is a fuser overheat error. This could be caused by power outage or fluctuation in the power.
go to service mode. Hold down both "home" and "simple screen" for about 5 sec. and then press "user tools"
once in service mode go to SP5810 reset fuser error.
and reboot the machine.
Feb 19, 2017 | Ricoh Aficio SP C830DN - Printer - color -...
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 03, 2011 | Ricoh Aficio 1018D Copier
In a 1018 machine i have an SC 194 code- functional problem
Normally one of these two problems.
Exposure lamp defective
• Dirty white plate
If the lamp comes on, take the glass out and clean the mirrors and glass well, Turn the glass upside down and clean the white reference areas well. That normally causes a SC-194
May 20, 2011 | Ricoh Aficio 1018D Copier
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
I Can not Reset error -codes
Its a fuser error code, the machine won't go back to working unless you go into svc mode and clear the error. I suggest calling a local tech.
Jan 08, 2008 | Ricoh Aficio 1018D Copier
759 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
